[QGIS-Developer] gdal 3.1 in OSGeo4W/QGIS 3.14?
Idan Miara
idan at miara.com
Sun Jun 21 05:24:01 PDT 2020
Hi Jürgen and all,
I can't see gdal 3.1 and Proj 7 in OSGeo4W.
I do see there gdal-dev 3.2 and proj-dev 7.1.
Does it mean that QGIS 3.14 is being packed with gdal 3.0 and Proj 6.3?
Kind regards,
Idan
On Thu, 28 May 2020 at 05:19, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 27 May 2020 at 02:37, Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
> > Hi,
> > Le mar. 26 mai 2020 à 18:21, Jürgen E. Fischer <jef at norbit.de> a écrit :
> >> Hi,
> >> On Mon, 25. May 2020 at 17:34:14 +0300, Idan Miara wrote:
> >> > I can't find gdal 3.1 in OSGeo4W, but only gdal 3.04 and 3.2
> (gdal-dev).
> >> > QGIS master depends on gdal-dev (3.2), but since QGIS 3.14 supposed
> to be
> >> > released in less then a month, won't it make sense to test it against
> gdal
> >> > 3.1 as gdal 3.2 won't be released before QGIS 3.14?
> >> And what about PROJ7?
> >> See also
> https://lists.osgeo.org/pipermail/qgis-developer/2020-February/060259.html
> > according to the bug tracker, the mentionned bug has been fixed.
> > @Nyall Dawson do you know about any other blocker on PROJ side that
> would justify to stick with 6.x versions in OSGEO4W?
> No blockers that I know of. I've been tracking proj/gdal master and I
> think we should upgrade.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200621/26da5a7d/attachment.html>
