[QGIS-Developer] Add function group to functions_help JSON files
Alexandre Neto
senhor.neto at gmail.com
Sun Jun 28 08:27:28 PDT 2020
Bump, sorry...
A segunda, 22/06/2020, 11:06, Alexandre Neto <senhor.neto at gmail.com>
escreveu:
> Hi,
> *TL;DR;*
> Would it be ok to add a group key in the function help JSON files?
> Something like this:
> "name": "array_agg",
> "type": "function", * "group": "Aggregates",*
> "description": "Returns an array of aggregated values from a field or
> expression.",
> "arguments": [
> {"arg": "expression", "description": "sub expression of field to
> aggregate"},
> {"arg": "group_by", "optional": true, "description": "optional expression
> to use to group aggregate calculations"},
> {"arg": "filter", "optional": true, "description": "optional expression to
> use to filter features used to calculate aggregate"},
> {"arg": "order_by", "optional": true, "description": "optional expression
> to use to order features used to calculate aggregate"}
> "examples": [
> { "expression": "array_agg(\"name\",group_by:=\"state\")", "returns":"list
> of name values, grouped by state field"}
> *WHY*
> I am following Thomas Grattier effort to put all expression functions in a
> single HTML page:
> https://gist.githack.com/ThomasG77/0c6862fb2b6b3fc301ea994733688ea5/raw/99ecc5e6127e7238814da330a4d5d0b9fa2afe4e/qgis-3-12-expressions-single-page.html
> This is how he did it:
> https://gist.github.com/ThomasG77/0c6862fb2b6b3fc301ea994733688ea5
> This made me think that would be great to have a complete list like this
> on our documentation. But, unfortunately we can't use his approach which
> generates HTML
> My idea would be to use the JSON files in QGIS\QGIS to semi-automagically
> populate the function list with Sphinx format files. Which would be much
> easier to do, if there is a group key in each function.
> https://github.com/qgis/QGIS-Documentation/issues/5747
> Thanks,
> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200628/4dcf7950/attachment-0001.html>
