[QGIS-Developer] QGIS testing workflow with QgsMultiRenderChecker (on Windows and Travis)
Even Rouault even.rouault at spatialys.com
Tue Jun 30 02:04:00 PDT 2020
On mardi 30 juin 2020 14:20:50 CEST Rizky Maulana Nugraha wrote:
> Hi Olivier,
> Maybe this helps. You can run build in debug mode in travis. I usually just
> make a private repo with a minimum script to run that said tests. Then
you
> can ssh into the build.
Slightly more convenient is to use locally the Docker build method that is
used by QGIS
See https://github.com/qgis/QGIS/tree/master/.docker#building
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200630/52f776d9/attachment-0001.html>
More information about the QGIS-Developer mailing list
