[QGIS-Developer] QGIS testing workflow with QgsMultiRenderChecker (on Windows and Travis)
Olivier Dalang olivier.dalang at gmail.com
Tue Jun 30 02:56:29 PDT 2020
Hi Even, Hi Rizky,
Thanks for your answers ! I just learned from Matthias about the existence
of cdash.orfeo-toolbox.org (for which there's a tinyurl link at the bottom
of each travis run) that actually has exactly what I needed (for example
https://cdash.orfeo-toolbox.org/testDetails.php?test=20613873&build=46050).
Cheers,
Olivier
On Tue, 30 Jun 2020 at 11:04, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 30 juin 2020 14:20:50 CEST Rizky Maulana Nugraha wrote:
> > Hi Olivier,
> > Maybe this helps. You can run build in debug mode in travis. I usually
> just
> > make a private repo with a minimum script to run that said tests. Then
> you
> > can ssh into the build.
> Slightly more convenient is to use locally the Docker build method that is
> used by QGIS
> See https://github.com/qgis/QGIS/tree/master/.docker#building
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200630/dab61d98/attachment.html>
More information about the QGIS-Developer mailing list
