[QGIS-Developer] changes in QGIS development with git
    Etienne Trimaille
    etienne.trimaille at gmail.com
    Tue Mar  3 06:15:18 PST 2020
You should rename your fork. You are still using the old name "Quantum-GIS"
and not QGIS ?
Le mar. 3 mars 2020 à 15:10, William Kyngesburye <woklist at kyngchaos.com> a
écrit :
> OK, now a backporting problem.  The backport run appears to be failing
> because it can't find my repository.  But the merge had no problem finding
> my repository.  huh?
> For 2 PRs now.
> William Kyngesburye
> <kyngchaos at kyngchaos.com>
> <http://www.kyngchaos.com>
> Don't Panic
> On Mar 2, 2020, at 11:37 AM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> Thanks.  I can add labels.
> First one failed travis-ci.  Which is odd... failed a test completely
> unrelated to this change.
> William Kyngesburye
> Don't Panic
> On Mar 2, 2020, at 3:10 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Le dim. 1 mars 2020 à 20:04, William Kyngesburye <woklist at kyngchaos.com>
> a écrit :
>> It's been a couple years since I made a commit with git, and I find that
>> I can't do that any more.  It appears master (and branches?) are locked so
>> that only travis-ci-validated commits can be pushed.  That means I have to
>> use a github fork and make pull requests, yay.  I just want to make sure I
>> have this correct now.
>> I figured out how to reset my 8 year old fork to current master.
>> The PR process from my years-old notes:
>> 1. merge upstream changes to my fork
>> 2. make my changes
>> 3. push my changes to my fork
>> 4. make PR to qgis upstream
>> 5. (new) wait for travis-ci to succeed
> an added step is to wait for a positive review now
>> 6. merge PR
>> One thing I'm not sure about is backporting.  I've seen [Backport] tagged
>> messages from Github.  And I recall talk about problems with the automated
>> backporting bot/app (fixed?).
> yes it should be working
>> How do I handle backporting?  Most of the changes I need to make need to
>> be backported.
> the PR must be labeled with "backport _branchname_". If you cannot define
> the label (rights) just ask for it to be labeled.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200303/af11be51/attachment.html>
