[QGIS-Developer] changes in QGIS development with git
William Kyngesburye woklist at kyngchaos.com
Tue Mar 3 07:02:02 PST 2020
Hmm, yes still old name.  But the original PR succeeds.  Shouldn't the backport bot use what's in the PR that defines the fork?
William Kyngesburye
<kyngchaos at kyngchaos.com>
<http://www.kyngchaos.com>
Don't Panic
> On Mar 3, 2020, at 8:15 AM, Etienne Trimaille <etienne.trimaille at gmail.com> wrote:
> You should rename your fork. You are still using the old name "Quantum-GIS" and not QGIS ?
>> Le mar. 3 mars 2020 à 15:10, William Kyngesburye <woklist at kyngchaos.com> a écrit :
>> OK, now a backporting problem.  The backport run appears to be failing because it can't find my repository.  But the merge had no problem finding my repository.  huh?
>> For 2 PRs now.
>> William Kyngesburye
>> Don't Panic
>>>> On Mar 2, 2020, at 11:37 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> Thanks.  I can add labels.
>>> First one failed travis-ci.  Which is odd... failed a test completely unrelated to this change.
>>> William Kyngesburye
>>> Don't Panic
>>>>> On Mar 2, 2020, at 3:10 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>>>>> Le dim. 1 mars 2020 à 20:04, William Kyngesburye <woklist at kyngchaos.com> a écrit :
>>>>> It's been a couple years since I made a commit with git, and I find that I can't do that any more.  It appears master (and branches?) are locked so that only travis-ci-validated commits can be pushed.  That means I have to use a github fork and make pull requests, yay.  I just want to make sure I have this correct now.
>>>>> I figured out how to reset my 8 year old fork to current master.
>>>>> The PR process from my years-old notes:
>>>>> 1. merge upstream changes to my fork
>>>>> 2. make my changes
>>>>> 3. push my changes to my fork
>>>>> 4. make PR to qgis upstream
>>>>> 5. (new) wait for travis-ci to succeed
>>>> an added step is to wait for a positive review now
>>>>> 6. merge PR
>>>>> One thing I'm not sure about is backporting.  I've seen [Backport] tagged messages from Github.  And I recall talk about problems with the automated backporting bot/app (fixed?).
>>>> yes it should be working
>>>>> How do I handle backporting?  Most of the changes I need to make need to be backported.
>>>> the PR must be labeled with "backport _branchname_". If you cannot define the label (rights) just ask for it to be labeled.
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200303/09b55a79/attachment-0001.html>
More information about the QGIS-Developer mailing list
