[QGIS-Developer] GeoPDF not available with GDAL 3.0.4
matteo matteo.ghetta at gmail.com
Mon Mar 9 01:52:19 PDT 2020
Hi Jorge,
> My gdalinfo returns:
> gdalinfo --formats | grep -i pdf
>   PDF -raster,vector- (rw+vs): Geospatial PDF
> Can you check your's gdalinfo --formats output?
same for me
matteo at debian:~$ gdalinfo --formats | grep -i pdf
> Did you compile it? I compile gdal myself and I use the option:
> --with-pdfium=/usr/local
no just updated from debian sid packages, so standard one. I just
compiled QGIS as usual.
GDAL and OGR algorithms seem to work fine, geopdf is not available...
> To compile PDFium, use Even's receipt:
> git clone https://github.com/rouault/pdfium_build_gdal_3_1
> cd pdfium_build_gdal_3_1/
> ./build_linux.sh
> sudo cp -r install/include /usr/local
> sudo cp -r install/lib /usr/local
> sudo ldconfig
> Then compile GDAL.
Cheers and thanks
Matteo
More information about the QGIS-Developer mailing list
