[QGIS-Developer] More PR problems
Nyall Dawson
nyall.dawson at gmail.com
Fri Mar 13 15:00:00 PDT 2020
On Sat, 14 Mar 2020 at 04:20, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I'm having a different problem now with another PR - travis error from Auto set milestone on PR. Test #586 fails with
> CMake Error at PyQgsOfflineEditingWFS.cmake:15 (MESSAGE):
> 5102 Test failed: 124
I'd suggest ignoring the ci failures for your work at the moment --
the CI infrastructure is going through some pains as we've a number of
simultaneously flaky tests. They'll get solved (or disabled), but in
the meantime you can be confident it's **not** related to your work!
Nyall
> This time it periodically retries and I'm getting a lot of notification emails.
> Again, it appears to be completely unrelated to my PR.
> And, still no luck with the backport bot. Very frustrating.
> William Kyngesburye
> <kyngchaos at kyngchaos.com>
> <http://www.kyngchaos.com>
> Don't Panic
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
