[QGIS-Developer] QGIS Doc Travis
Alexandre Neto senhor.neto at gmail.com
Sun Mar 15 03:03:27 PDT 2020
Hi Richard,
Instead of travis, maybe we can try to use github actions instead?
Alex
On Sun, Mar 15, 2020 at 8:43 AM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 3/15/20 8:57 AM, matteo wrote:
> > That's what comes into my mind:
> > * verify Transifex pulling/pushing
> > * apache on the server to publish the docs
> > * ... what else?
> @Raymond thanks for organising the hackfest! Sorry for not being
> there... But the 'doc-team' did some things related to documentations
> because there WAS a hackfest \o/
> There are 2 things I want to discuss here.
> First our main goal: "KISS".
> Everybody on windows or linux should be able to build at least the
> english docs.
> Second: stick to Sphinx and it's tools as much as possible (e.g. instead
> of custom scripts: use sphinx-intl to create transifex stuff).
> My main 2 questions, I would like to discuss:
> -1- CAN we use Travis to build the translated site (daily) (technically:
> yes, I know, but...)
> -2- WHICH process should be responsible for the pulling of the transifex
> translations into the build process
> Ad -1-
> "Make doctest" will use the qgis/qgis docker container to build and run
> the tests. Travis is happy with that [4]
> So we could update or base a new image on it containing all language
> related stuff, and use travis to build all languages. Current 3.4 builds
> pull fresh from transifex (making a language build lasts for half an
> hour now sometimes...) If we push the po files into github, it will only
> be 10 minutes.
> But my main question is: can/should we 'misuse' travis to build all
> those (currently 18) languages daily.
> Ad -2-
> Several options:
> - during our main build, the build pulls (tx pull) from transifex. Is
> what we do now: Transifex is main repo for translations. IF an
> individual wants to build a translated doc, she/he needs to pull the
> translations from transifex itself (which is a disadvantage, as pulling
> translations from tx is SLOW...)
> - we run a daily script which pulls the translations from tx and commits
> those po files (for ALL languages to be build) in git-repo.
> Main advantage: we keep being boss over the po files ourselves, AND
> everybody can build translated docs, because the po files are (well 1
> day old...) in git
> - use the Transifex Github integration (I played with it one year ago,
> and then it could not handle our long resource handles at that time...)
> I think I prefer the second or third option, will push nl, it and fr
> translations into git later today (by just pulling the 3.4 translations
> from build server), so everybody can try to build translated sites too.
> Als together with maybe building it on travis, it is probably the best
> way..
> Want to see current status?
> - vanilla Sphinx local ( EVERYBODY can try to build branch qgisdoc2020
> NOW on windows and linux, see README [0] )
> - vanilla Sphinx remote ('make site' works if you can like me rsync to
> qgis2 [1]) (NOTE: a lot has to be done there....)
> - everybody should now be able to 'just edit' on github [2]
> - 'make doctest' (== building in te qgis/qgis docker image) is also
> working, see travis [4] qgisdoc2020 branch there
> Sorry for being rather long, and while writing maybe answering my own
> questions :-)
> But I really really hope we can keep stuff as simple as possible and
> encourage everybody to JOIN. Please contact us via documentation list
> About PDF's: maybe later... but I'm OK without those...
> So if you want them: join us
> Regards,
> [0] https://github.com/qgis/QGIS-Documentation/tree/qgisdoc2020
> [1] https://docs.qgis.org/3.10/
> [3]
> https://github.com/qgis/QGIS-Documentation/blob/qgisdoc2020/docs/user_manual/introduction/getting_started.rst
> [4] https://travis-ci.org/github/qgis/QGIS-Documentation
> [5] https://docs.transifex.com/transifex-github-integrations/github-tx-ui
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200315/3de1808a/attachment.html>
More information about the QGIS-Developer mailing list
