[QGIS-Developer] QGIS Doc Travis
r.m.aguilardearchila at utwente.nl r.m.aguilardearchila at utwente.nl
Sun Mar 15 07:37:21 PDT 2020
Hey. Guys.
Just to let you know. I built the doc in Windows. Looks beautiful.
I just felt a bit confusing with the windows instructions.
Because when I cloned the repo I did not get the make.bat ( I could not clone the qgisdoc2020 branch directly- beginner mistake?)
So, I needed to create the branch first before actually compile it.
Perhaps adding such make.bat in the master branch may help?
Nice work.
Cheers,
Rosa
MSc Rosa Aguilar
PhD Candidate
Faculty of Geoinformation Science and Earth Observation
University of Twente
Enschede, The Netherlands
Telephone: +31 647616029
https://www.linkedin.com/in/rosamaguilar/?locale=en_US
https://rosaguilar.github.io/
-----Original Message-----
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On Behalf Of Richard Duivenvoorde
Sent: 15 March 2020 09:44
To: matteo <matteo.ghetta at gmail.com>; qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] QGIS Doc Travis
On 3/15/20 8:57 AM, matteo wrote:
> That's what comes into my mind:
> * verify Transifex pulling/pushing
> * apache on the server to publish the docs
> * ... what else?
@Raymond thanks for organising the hackfest! Sorry for not being there... But the 'doc-team' did some things related to documentations because there WAS a hackfest \o/
There are 2 things I want to discuss here.
First our main goal: "KISS".
Everybody on windows or linux should be able to build at least the english docs.
Second: stick to Sphinx and it's tools as much as possible (e.g. instead of custom scripts: use sphinx-intl to create transifex stuff).
My main 2 questions, I would like to discuss:
-1- CAN we use Travis to build the translated site (daily) (technically:
yes, I know, but...)
-2- WHICH process should be responsible for the pulling of the transifex translations into the build process
Ad -1-
"Make doctest" will use the qgis/qgis docker container to build and run the tests. Travis is happy with that [4]
So we could update or base a new image on it containing all language related stuff, and use travis to build all languages. Current 3.4 builds pull fresh from transifex (making a language build lasts for half an hour now sometimes...) If we push the po files into github, it will only be 10 minutes.
But my main question is: can/should we 'misuse' travis to build all those (currently 18) languages daily.
Ad -2-
Several options:
- during our main build, the build pulls (tx pull) from transifex. Is what we do now: Transifex is main repo for translations. IF an individual wants to build a translated doc, she/he needs to pull the translations from transifex itself (which is a disadvantage, as pulling translations from tx is SLOW...)
- we run a daily script which pulls the translations from tx and commits those po files (for ALL languages to be build) in git-repo.
Main advantage: we keep being boss over the po files ourselves, AND everybody can build translated docs, because the po files are (well 1 day old...) in git
- use the Transifex Github integration (I played with it one year ago, and then it could not handle our long resource handles at that time...)
I think I prefer the second or third option, will push nl, it and fr translations into git later today (by just pulling the 3.4 translations from build server), so everybody can try to build translated sites too.
Als together with maybe building it on travis, it is probably the best way..
Want to see current status?
- vanilla Sphinx local ( EVERYBODY can try to build branch qgisdoc2020 NOW on windows and linux, see README [0] )
- vanilla Sphinx remote ('make site' works if you can like me rsync to
qgis2 [1]) (NOTE: a lot has to be done there....)
- everybody should now be able to 'just edit' on github [2]
- 'make doctest' (== building in te qgis/qgis docker image) is also working, see travis [4] qgisdoc2020 branch there
Sorry for being rather long, and while writing maybe answering my own questions :-)
But I really really hope we can keep stuff as simple as possible and encourage everybody to JOIN. Please contact us via documentation list
About PDF's: maybe later... but I'm OK without those...
So if you want them: join us
Regards,
[0] https://github.com/qgis/QGIS-Documentation/tree/qgisdoc2020
[1] https://docs.qgis.org/3.10/
[3]
https://github.com/qgis/QGIS-Documentation/blob/qgisdoc2020/docs/user_manual/introduction/getting_started.rst
[4] https://travis-ci.org/github/qgis/QGIS-Documentation
[5] https://docs.transifex.com/transifex-github-integrations/github-tx-ui
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
