[QGIS-Developer] More PR problems
William Kyngesburye
woklist at kyngchaos.com
Mon Mar 16 18:51:06 PDT 2020
Still getting same failure.
William Kyngesburye
<kyngchaos at kyngchaos.com>
<http://www.kyngchaos.com>
Don't Panic
> On Mar 16, 2020, at 7:20 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Sat, 14 Mar 2020 at 10:05, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Ah, but I can't proceed with merging the PR until the ci succeeds. And I don't see a way to bypass the failing test, though others could when another PR failed an unrelated test.
> Quite a lot of test fixes committed over the last couple of days.
> Fingers crossed this will stabilise things!
> Nyall
>> William Kyngesburye
>> Don't Panic
>>>> On Mar 13, 2020, at 5:00 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> On Sat, 14 Mar 2020 at 04:20, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>> I'm having a different problem now with another PR - travis error from Auto set milestone on PR. Test #586 fails with
>>>> CMake Error at PyQgsOfflineEditingWFS.cmake:15 (MESSAGE):
>>>> 5102 Test failed: 124
>>> I'd suggest ignoring the ci failures for your work at the moment --
>>> the CI infrastructure is going through some pains as we've a number of
>>> simultaneously flaky tests. They'll get solved (or disabled), but in
>>> the meantime you can be confident it's **not** related to your work!
>>> Nyall
>>>> This time it periodically retries and I'm getting a lot of notification emails.
>>>> Again, it appears to be completely unrelated to my PR.
>>>> And, still no luck with the backport bot. Very frustrating.
>>>> William Kyngesburye
>>>> Don't Panic
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
