[QGIS-Developer] More PR problems
Nyall Dawson nyall.dawson at gmail.com
Mon Mar 16 17:20:40 PDT 2020
On Sat, 14 Mar 2020 at 10:05, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Ah, but I can't proceed with merging the PR until the ci succeeds.  And I don't see a way to bypass the failing test, though others could when another PR failed an unrelated test.
Quite a lot of test fixes committed over the last couple of days.
Fingers crossed this will stabilise things!
Nyall
> William Kyngesburye
> <kyngchaos at kyngchaos.com>
> <http://www.kyngchaos.com>
> Don't Panic
> > On Mar 13, 2020, at 5:00 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> > On Sat, 14 Mar 2020 at 04:20, William Kyngesburye <woklist at kyngchaos.com> wrote:
> >> I'm having a different problem now with another PR - travis error from Auto set milestone on PR.  Test #586 fails with
> >> CMake Error at PyQgsOfflineEditingWFS.cmake:15 (MESSAGE):
> >> 5102 Test failed: 124
> > I'd suggest ignoring the ci failures for your work at the moment --
> > the CI infrastructure is going through some pains as we've a number of
> > simultaneously flaky tests. They'll get solved (or disabled), but in
> > the meantime you can be confident it's **not** related to your work!
> > Nyall
> >> This time it periodically retries and I'm getting a lot of notification emails.
> >> Again, it appears to be completely unrelated to my PR.
> >> And, still no luck with the backport bot.  Very frustrating.
> >> William Kyngesburye
> >> Don't Panic
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
