[QGIS-Developer] Geopackage FID columns: i HATE them!!!!
Régis Haubourg
regis.haubourg at gmail.com
Thu Mar 19 02:28:22 PDT 2020
+1000. I was so relieved of the fid/oid/mapinfo_id when QGIS arrived and
allowed business logic primary keys.
Le jeu. 19 mars 2020 à 07:52, Nathan Woodrow <madmanwoo at gmail.com> a écrit :
> I agree.
> If there is an ID that is used internally as a unique primary key it
> should never be shown to the user. It should not be expected to be edited
> outside of the provider's control or be stable between edits.
> If you need a stable ID for reference you should make your own {{insert
> rant about people wanting to use increating ints as a reference ID}}
> On Thu, Mar 19, 2020 at 4:04 PM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> Hi list,
>> Just wondering what everyone's thoughts are about geopackage FID
>> columns. Personally, I find them an absolute nightmare to deal with,
>> resulting in annoying (and dangerous) issues when trying to save
>> geopackage edits, such as
>> - field type issues: converting certain formats to geopackage fails,
>> because existing fields with name "fid" are of an incompatible type
>> with geopackage. Solution: manually uncheck the "fid" field from the
>> "save as" dialog.
>> - unique constraint violations: we've mostly fixed this in processing,
>> but it's still unfortunately really common to get failures when saving
>> edits to geopackage because some operation has resulted in duplicate
>> fids. This can be a nightmare to fix, if it's even possible to do so.
>> I personally HATE HATE HATE these columns, and would rather I never
>> saw them ever again. Does anyone else feel the same? If so, could we
>> potentially just permanently hide these columns from QGIS and avoid
>> all these dangerous issues for users?
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200319/90779977/attachment.html>
