[QGIS-Developer] Visual studio 2019 building issue
Martin Dobias wonder.sk at gmail.com
Mon Mar 23 05:23:39 PDT 2020
Hi Belgacem
I think is simply based on the version of MSVC that Jürgen (our
windows release guru) uses to build OSGeo4W and QGIS. I am not sure
how is it with support of other versions of MSVC - if that's supported
at all - maybe Jürgen could comment better.
Generally, I would strongly suggest that you use Linux for QGIS
development if you can. I would say it what 90% of QGIS developers use
and the developer experience is the best (and with largest pool of
people able to help if things are not working as expected). On Windows
the compilation sometimes involves furious shouting at the computer
screen :-)
Cheers
Martin
On Mon, Mar 23, 2020 at 12:40 PM BELGACEM NEDJIMA <gb_nedjima at esi.dz> wrote:
> Hi,
> I was trying to build QGIS using visual studio 2019 and found that the 2 scripts msvc-env.bat and configonly.bat is using an old visual studio version (the paths to the compiler are clearly for an old). Is it required to use an older version or just a bug ?
> Link to the scripts :
> https://github.com/qgis/QGIS/blob/master/ms-windows/osgeo4w/msvc-env.bat
> https://github.com/qgis/QGIS/blob/master/ms-windows/osgeo4w/configonly.bat
> Have a nice day and stay safe,
> Regads
> Belgacem Nedjima
> 4th year computer science and engineering student student.
> https://github.com/NEDJIMAbelgacem
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
