[QGIS-Developer] Fwd: Compiling Problem QGis 3.12.1 on CentOS 7.6
piaff33z piaff33z at gmail.com
Tue Mar 24 09:42:23 PDT 2020
Hello all, I need some help to compile and install last version of QGis
3.12.1 :-)
Below my explanation about my last last blocking point.
Context :
My system is an CentOS Linux release 7.6.1810 (Core) on Linux
3.10.0-957.10.1.el7.x86_64 #1 SMP
Making tools
Provide by CentOS :
gcc-c++-4.8.5-39.el7.x86_64
libgcc-4.8.5-39.el7.x86_64
Devtoolset installed if some products need to be compiled with more recent
compiler :
devtoolset-7-gcc-7.3.1-5.16.el7.x86_64
devtoolset-7-gcc-c++-7.3.1-5.16.el7.x86_64
I compiled successfully software below to have last versions
lrwxrwxrwx. 1 root root    11 23 mars  15:15 gdal -> gdal-3.0.4/
drwxr-xr-x. 7 root root  4096 23 mars  15:15 gdal-3.0.4
lrwxrwxrwx. 1 root root    11 23 mars  15:52 grass -> grass-7.8.2
drwxr-xr-x. 4 root root  4096 23 mars  15:57 grass-7.8.2
lrwxrwxrwx. 1 root root    19 23 mars  17:11 libspatialite ->
libspatialite-4.3.0
drwxr-xr-x. 4 root root  4096 23 mars  17:11 libspatialite-4.3.0
drwx------. 2 root root 16384 21 mars   2019 lost+found
lrwxrwxrwx. 1 root root    10 23 mars  17:23 proj -> proj-4.9.3
drwxr-xr-x. 6 root root  4096 23 mars  17:23 proj-4.9.3 ( I tried with
proj-7.0.0 but is too recent for QGis 3.12.1 :-( )
lrwxrwxrwx. 1 root root    11 23 mars  14:05 sqlite -> sqlite-3.32
drwxr-xr-x. 6 root root  4096 23 mars  14:05 sqlite-3.32
Qt5 is provide by my distribution and I didn't try to compile it from source
qca-qt5-2.1.3-3.el7.x86_64
qt5-qttools-common-5.9.7-1.el7.noarch
qt5-qtwebkit-devel-5.9.1-2.el7.x86_64
qt5-qtwayland-devel-5.9.7-1.el7.x86_64
qt5-qtbase-gui-5.9.7-2.el7.x86_64
qt5-qtlocation-5.9.7-1.el7.x86_64
python36-qt5-webkit-5.12.1-3.el7.x86_64
qt5-qtgraphicaleffects-5.9.7-1.el7.x86_64
qt5-qtquickcontrols2-devel-5.9.7-1.el7.x86_64
qt5-qtstyleplugins-5.0.0-29.el7.x86_64
qt5-qtbase-odbc-5.9.7-2.el7.x86_64
qt5-qtserialport-5.9.7-1.el7.x86_64
qt5-qtenginio-1.6.2-2.el7.x86_64
qt5-qttools-devel-5.9.7-1.el7.x86_64
qt5-qtaccountsservice-devel-0.1.1-3.el7.x86_64
qt5-qtenginio-devel-1.6.2-2.el7.x86_64
qca-qt5-gnupg-2.1.3-3.el7.x86_64
qca-qt5-devel-2.1.3-3.el7.x86_64
qt5-qtwebkit-5.9.1-2.el7.x86_64
qt5-qttools-5.9.7-1.el7.x86_64
qt5-qtimageformats-5.9.7-1.el7.x86_64
qt5ct-0.35-2.el7.x86_64
qt5-qtx11extras-5.9.7-1.el7.x86_64
qt5-qtdeclarative-5.9.7-1.el7.x86_64
qt5-qtmultimedia-5.9.7-1.el7.x86_64
python36-qt5-5.12.1-3.el7.x86_64
qt5-linguist-5.9.7-1.el7.x86_64
qt5-qtconfiguration-0.3.0-3.el7.x86_64
qt5-qt3d-5.9.7-1.el7.x86_64
qt5-qtquick1-devel-5.7.1-2.2bc722agit.el7.x86_64
qt5-qtwebchannel-devel-5.9.7-1.el7.x86_64
qt5-qtdeclarative-static-5.9.7-1.el7.x86_64
qca-qt5-pkcs11-2.1.3-3.el7.x86_64
qca-qt5-nss-2.1.3-3.el7.x86_64
qt5-rpm-macros-5.9.7-2.el7.noarch
qt5-qtserialport-devel-5.9.7-1.el7.x86_64
qt5-qttools-libs-help-5.9.7-1.el7.x86_64
qt5-qtwebsockets-5.9.7-1.el7.x86_64
qt5-qttools-libs-designercomponents-5.9.7-1.el7.x86_64
qt5-qtscript-devel-5.9.7-1.el7.x86_64
qt5-qtcanvas3d-5.9.7-1.el7.x86_64
qt5-qdbusviewer-5.9.7-1.el7.x86_64
qt5-qtbase-static-5.9.7-2.el7.x86_64
qt5-qtsensors-devel-5.9.7-1.el7.x86_64
qca-qt5-cyrus-sasl-2.1.3-3.el7.x86_64
qt5-qtbase-devel-5.9.7-2.el7.x86_64
qt5-qtsvg-devel-5.9.7-1.el7.x86_64
qt5-qttools-libs-designer-5.9.7-1.el7.x86_64
qt5-designer-5.9.7-1.el7.x86_64
qt5-qtquick1-5.7.1-2.2bc722agit.el7.x86_64
qt5-qtquickcontrols-5.9.7-1.el7.x86_64
qt5-qtbase-mysql-5.9.7-2.el7.x86_64
qt5-qtbase-postgresql-5.9.7-2.el7.x86_64
qca-qt5-softstore-2.1.3-3.el7.x86_64
qt5-qtbase-common-5.9.7-2.el7.noarch
qt5-qtserialbus-5.9.7-1.el7.x86_64
qt5-qtwebchannel-5.9.7-1.el7.x86_64
python-qt5-rpm-macros-5.12.1-3.el7.noarch
qt5-qtlocation-devel-5.9.7-1.el7.x86_64
qt5-qtx11extras-devel-5.9.7-1.el7.x86_64
qt5-qtxmlpatterns-devel-5.9.7-1.el7.x86_64
qt5-qt3d-devel-5.9.7-1.el7.x86_64
qt5-qtwebsockets-devel-5.9.7-1.el7.x86_64
qca-qt5-gcrypt-2.1.3-3.el7.x86_64
qt5-qtserialbus-devel-5.9.7-1.el7.x86_64
python36-pyqt5-sip-4.19.16-3.el7.x86_64
qt5-qtscript-5.9.7-1.el7.x86_64
qt5-qtconnectivity-devel-5.9.7-1.el7.x86_64
qca-qt5-logger-2.1.3-3.el7.x86_64
qt5-qtsvg-5.9.7-1.el7.x86_64
qt5-qtconnectivity-5.9.7-1.el7.x86_64
qt5-doctools-5.9.7-1.el7.x86_64
qt5-qtaccountsservice-0.1.1-3.el7.x86_64
qt5-assistant-5.9.7-1.el7.x86_64
qca-qt5-botan-2.1.3-3.el7.x86_64
qca-qt5-ossl-2.1.3-3.el7.x86_64
qt5-qtbase-5.9.7-2.el7.x86_64
qt5-qtsensors-5.9.7-1.el7.x86_64
qt5-qtdeclarative-devel-5.9.7-1.el7.x86_64
qt5-qtquickcontrols2-5.9.7-1.el7.x86_64
qt5-qtconfiguration-devel-0.3.0-3.el7.x86_64
qt5-qtxmlpatterns-5.9.7-1.el7.x86_64
python36-qt5-base-5.12.1-3.el7.x86_64
qt5-qtwayland-5.9.7-1.el7.x86_64
qt5-qtmultimedia-devel-5.9.7-1.el7.x86_64
qt5-qttools-static-5.9.7-1.el7.x86_64
Result after compiliing with cmake3 --version
cmake3 version 3.14.6
[root at build-master]# cmake3 .. -DGDAL_LIBRARY=/opt/gdal/lib
-DPROJ_LIBRARY=/opt/proj/lib -DPROJ_INCLUDE_DIR=/opt/proj/include
-DSQLITE3_INCLUDE_DIR=/opt/sqlite/include -DSQLITE3_LIBRARY=/opt/sqlite/lib
-DGRASS_INCLUDE_DIR=/opt/grass/include -DGRASS_LIBRARY=/opt/grass/lib
-- QGIS version: 3.12.1 București (31201)
-- Found OpenCL C++ headers: /usr/include
*-- Could not find GRASS 7*
-- Found Proj: /opt/proj/lib version 4 (4.9.3)
-- Found GEOS: /usr/lib64/libgeos_c.so (3.4.2)
-- Found GDAL: /opt/gdal/lib (3.0.4)
-- Found Expat: /lib64/libexpat.so
-- Found Qwt: /usr/lib64/libqwt.so (6.1.1)
-- Found libzip: /usr/lib64/libzip.so
-- Found Sqlite3: /opt/sqlite/lib
-- Found PostgreSQL: /usr/lib64/libpq.so
-- Qt WebKit support enabled
-- Found Qt version: 5.9.7
-- Found QScintilla2: /usr/lib64/libqscintilla2.so (2.8)
-- Found QCA: /usr/lib64/libqca-qt5.so (2.0.3)
-- QCA OpenSSL plugin C++ check failed to compile
-- QCA OpenSSL plugin C++ check compile output:
-- Change Dir:
/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/gmake cmTC_2370e/fast
/usr/bin/gmake -f CMakeFiles/cmTC_2370e.dir/build.make
gmake[1] : on entre dans le répertoire «
/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp »
Building CXX object CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o
/usr/bin/c++   -I/usr/include/qt5 -I/usr/include/qt5/QtCore
-I/usr/lib64/qt5/./mkspecs/linux-g++ -I/usr/include/QtCrypto  -fPIC
-std=gnu++11 -o CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o -c
/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp/qcaossl.cpp
In file included from /usr/include/QtCrypto/qca.h:38:0,
                 from /usr/include/QtCrypto/QtCrypto:1,
                 from
/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp/qcaossl.cpp:2:
/usr/include/QtCrypto/qca_basic.h:318:14: erreur: ‘QIODevice’ has not been
declared
  void update(QIODevice *file);
gmake[1]: *** [CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o] Erreur 1
gmake[1] : on quitte le répertoire «
gmake: *** [cmTC_2370e/fast] Erreur 2
CMake Error at cmake/QCAMacros.cmake:76 (message):
  QCA OpenSSL plugin not found (run-time/unit-test dependency)
Call Stack (most recent call first):
  CMakeLists.txt:444 (FIND_QCAOSSL_PLUGIN_CPP)
-- Configuring incomplete, errors occurred!
See also
"/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeOutput.log".
See also
"/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeError.log".
Two problems :
   - What are the variables to tell where is Grass 7 path installation for
   my cmake3 call ?
   Is not clearly defined in ../cmake/FindGRASS.cmake like others cmake
   files ?
   - Could someone help me to understand what is missing in my system or
   compile parameters :-)
I can post CMakeOutput.log or CMakeError.log, but i don't be sure that this
mailing accept this type of sending...
Vic
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200324/1380c035/attachment.html>
More information about the QGIS-Developer mailing list
