[QGIS-Developer] QGIS build error in Ubuntu 18.04
Samweli smwltwesa6 at gmail.com
Tue Mar 31 04:49:36 PDT 2020
Hi Stephen,
Thanks a lot for your help, I have downgraded to PROJ 6.3.1 by installing it
from source. Now I get this error
[ 39%] Built target pyqtcompat
make[2]: *** No rule to make target
'/usr/lib/x86_64-linux-gnu/libspatialite.so', needed by
'output/lib/libqgis_core.so.3.13.0'.  Stop.
CMakeFiles/Makefile2:1320: recipe for target
'src/core/CMakeFiles/qgis_core.dir/all' failed
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
When I try to install libspatialite, it also installs PROJ 7, causing to
revert to the previous "invalid pointer" error!!
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
