[QGIS-Developer] QGIS build error in Ubuntu 18.04
Stephen Knox
stephenknox73 at gmail.com
Tue Mar 31 06:06:54 PDT 2020
Hi Samweli,
I was able to fix it last night with Proj 7 by doing the following (I have
a custom build of gdal, spatialite, qgis and proj):
- purge all libproj < 19 from /usr/local/lib or wherever your custom files
are kept
- Compile and install proj 7
- Recompile libspatialite against proj 7 (to do that I not only had to
specify the location for proj as above, but also set the
CFLAGS"-DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=1" in configure
- Recompile gdal against new libspatialite and proj7
- Finally recompile QGIS
On Tue, Mar 31, 2020 at 12:49 PM Samweli <smwltwesa6 at gmail.com> wrote:
> Hi Stephen,
> Thanks a lot for your help, I have downgraded to PROJ 6.3.1 by installing
> it
> from source. Now I get this error
> [ 39%] Built target pyqtcompat
> make[2]: *** No rule to make target
> '/usr/lib/x86_64-linux-gnu/libspatialite.so', needed by
> 'output/lib/libqgis_core.so.3.13.0'. Stop.
> CMakeFiles/Makefile2:1320: recipe for target
> 'src/core/CMakeFiles/qgis_core.dir/all' failed
> make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> Makefile:162: recipe for target 'all' failed
> make: *** [all] Error 2
> When I try to install libspatialite, it also installs PROJ 7, causing to
> revert to the previous "invalid pointer" error!!
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200331/cc5ea2d9/attachment-0001.html>
