[QGIS-Developer] Virtuel Fields are apparently stored as part of a style?
magerlin MAP at ramboll.dk
Tue May 5 05:28:30 PDT 2020
I am working with virtual fields in Field Calculator as I need to have
columns updated based on data from a dbf file present in the project folder
whenever I open the project.
I have two different styles set up for the layer with virtual fields and
after having edited some of the formulas for the virtual fields I was very
puzzled on what was going on?
Until I realized that the formulas had only been changed for the style that
was used for showing the layer when I made the edits. For the other style
the formulas were not edited.
Is this intentional or an error?
Regards Morten
Currently using Qgis 3.10.0
Windows 10, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
