[QGIS-Developer] Exe size mismatch
Jürgen E. Fischer jef at norbit.de
Thu May 7 02:46:02 PDT 2020
Hi Sachin,
On Thu, 07. May 2020 at 14:15:01 +0530, Sachin Kumar wrote:
> Thanks to everyone for solution.
> I had compiled using QGIS version 3.10.5 using 'package.cmd' on MSVC 2015
> and successfully created *QGIS-OSGeo4W-3.10.5-1-Setup-x86_64.exe* using
> creatensis.pl.
You didn't package your build, but the regular default, which is qgis-full,
which is currently 3.12.
Extract your packages to addons and exclude those packages when calling
calling creatensis.pl (ie. qgis-full qgis- qgis-common- …)
See also
https://lists.osgeo.org/pipermail/qgis-developer/2020-April/061042.html.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200507/0a84aa4d/attachment.sig>
More information about the QGIS-Developer mailing list
