[QGIS-Developer] Exe size mismatch
Sachin Kumar surveykshak at gmail.com
Thu May 7 01:45:01 PDT 2020
Thanks to everyone for solution.
I had compiled using QGIS version 3.10.5 using 'package.cmd' on MSVC 2015
and successfully created *QGIS-OSGeo4W-3.10.5-1-Setup-x86_64.exe* using
creatensis.pl.
Till here it correct, above underline version comes from
C:\xxxx\QGIS-release-3_10\CMakeLists.txt. After installation I get a folder
QGIS 3.10 at desktop contains files:
1. QGIS Desktop 3.12.2 with GRASS 7.8.2
2. QGIS Desktop 3.12.2
3. Qt Designer with QGIS 3.12.2 custom widgets
4. SAGA GIS (2.3.2)
5. OSGeo4W Shell
Why this " QGIS Desktop 3.12.2 " comes here instead of " QGIS Desktop
3.10.5 ". Unable to trace this.
Please suggest solution to this.
Regards
On Mon, 4 May 2020 at 21:16, Jürgen E. Fischer <jef at norbit.de> wrote:
> On Mon, 04. May 2020 at 17:42:08 +0530, Sachin Kumar wrote:
> > I have compiled on MSVC 2015, Windows 10. Till compile and install as in
> > C:/OSGeo4w/apps/qgis-test and run successful from cmd prompt.
> > When I tried to package it using perl creatensis.pl, it gives error
> > qgis_app.dll
> Did you meanwhile include the postinstall scripts to create the .env file
> on
> install?
> See also:
> https://lists.osgeo.org/pipermail/qgis-developer/2020-April/061042.html
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200507/7a6f9f1d/attachment.html>
More information about the QGIS-Developer mailing list
