[QGIS-Developer] GeoPackage - where are we -where do we go
Paolo Cavallini cavallini at faunalia.it
Fri May 8 02:52:20 PDT 2020
Hi MAtthias,
thanks for this very good review. Agreed on all points. As Werner
mentioned, the issue also impacts on incremental backups, causing lots
of wasted disk space.
Cheers.
Il 08/05/20 11:34, Werner Macho ha scritto:
> Hi Matthias,
> May I add another pain here?
> Storing gpkg in the cloud means syncing even after the file was only
> opened in QGIS and nothing has changed inside - it was only opened to
> view something.
> On very large gpkg files this is also not really nice.
> (Maybe I am just using gpkg wrong, but at least this happens on my
> installation)
> regards
> Werner
> On Fri, May 8, 2020 at 11:31 AM Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi list,
>     I wondered about the state of GeoPackage. Personally, cince it has
>     been introduced to qgis and evenmore since it has been selected as
>     the default format, I have never grown to fully and completely.
>     I do not want to trigger a evangelical discussion here. I'd like to
>     see where we are and what we can reasonably do to have a default
>     file format which can be recommended with no bad feelings.
>     Here follow a couple of observations over the years, some of them
>     properties of the specs I believe:
>     * The fid requirement
>       I sometimes want my features to be identified by uuids or others.
>     They also tend to accumulate if derived datasets are created
>     (through processing etc). If I need some pseudo stable primary key
>     there is a rowid builtin into sqlite, we don't need a second one.
>       Possible mitigation: alter the ogr implementation. possibly alter
>     the standard (required?)
>     * The modification on r/o open
>       Has caused too much pain on git.
>       Possible mitigation: a) switch to journal mode=delete (not an easy
>     option because of https://issues.qgis.org/issues/15351) b) only
>     switch to wal mode when layers are put into edit mode (I have strong
>     doubts this is a safe thing to do)
>     * The network share freeze
>       Our default file should play nicely with (windows) network shares.
>     It's clear to everyone that we can't expect concurrent writes. But
>     it should "just work" for concurrent read by many.
>       Possible mitigation: switch to journal mode=delete for network
>     shares (we are looking into this)
>     * The wal file appearing next to the file
>       It is confusing to newcomers and looks almost like a sidecar file.
>     I would care less if it was put into some system cache folder
>     instead of just into my data folder. Or at least if it was a hidden
>     file.
>       Possible mitigation: switch to journal mode=delete (not an easy
>     * The couple of corrupted files I have received over the years which
>     could only be repaired by a command line "dump contents as sql and
>     execute into new file"
>       I have not found a way to reproduce this. Some of them were
>     produced by older qgis versions making it easy to violate foreign
>     key constraints and hard to recover. This has been fixed.
>       Possible mitigation: offer a "repair" option in qgis. Through
>     processing or "on the fly" upon detection.
>     *Default value magic replace values on insert (with no possibility
>     to pre-evaluate them)
>       E.g. a global sequence like on postgres would be nice. Can be
>     worked around through default values in qgis though.
>       Possible mitigation: a)add it as a feature to sqlite. b) use qgis
>     default values. c) live with it.
>     *The requirement for a single geometry column per table
>       I just don't see a good reason to forbid that
>       Possible mitigation: a) alter the standard. b) ignore the standard
>     and patch the ogr implementation.
>     I wonder how others feel about these topics.
>     - Are there more pain points I forgot to list?
>     - Do you see more approaches to mitigate these problems?
>     - Is someone already working on these issues?
>     It would be great to have a standard file format that we can fully
>     trust. Let's make a reality check if GeoPackage can be this format.
>     Best regards
>     Matthias Kuhn
>     matthias at opengis.ch <mailto:matthias at opengis.ch>
>     +41 (0)76 435 67 63 <tel:+41764356763>
>     OPENGIS.ch Logo <http://www.opengis.ch>
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini
www.faunalia.eu - QGIS.org
training, support, development on QGIS, PostGIS and more
More information about the QGIS-Developer mailing list
