[QGIS-Developer] GeoPackage - where are we -where do we go
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Fri May 8 06:10:57 PDT 2020
Hi all,
Interesting discussion!
Standard does not care (and should not care to great extent) about use
cases. Creating revisions and incremental changelogs is a common use case
(unless you work with
my-spatial_data_v010_final_draft_final_002_really-final_005.gpkg :) ), you
have those common use cases.
Providing a tool similar to geodiff or Detect dataset changes
algorithms can help users to overcome the limitation of standards...
Regards
Saber
On Fri, 8 May 2020 at 11:48, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Tim
> On 5/8/20 12:25 PM, Tim Sutton wrote:
> Hi
> On 8 May 2020, at 10:34, Werner Macho <werner.macho at gmail.com> wrote:
> Hi Matthias,
> May I add another pain here?
> Storing gpkg in the cloud means syncing even after the file was only
> opened in QGIS and nothing has changed inside - it was only opened to view
> something.
> On very large gpkg files this is also not really nice.
> (Maybe I am just using gpkg wrong, but at least this happens on my
> installation)
> In some cases you may be able to work around this by using geodiff from
> our fine friends over at Lutra. It will let you extract just the changes
> (if you have the original and the changed copy locally), then upload them
> to the server.
> Thanks for mentioning that. This might indeed be good for very controlled
> environments but adds quite a bit of additional requirements on logic and
> services. In those cases you are often better off setting up a postgres
> database directly.
> In this thread, let's focus on "how to get things to work properly for our
> standard geo container file."
> Matthias
> [1]https://github.com/lutraconsulting/geodiff
> Regards
> Tim
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> I'd love to connect. Here's my calendar link
> <https://calendly.com/timlinux/30min> to make finding time easy.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/5ab62e01/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/5ab62e01/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
