[QGIS-Developer] Flatgeobuf for processing
Matthias Kuhn matthias at opengis.ch
Sat May 9 00:18:47 PDT 2020
Hi
On 5/9/20 9:04 AM, Alexander Bruy wrote:
> Not sure this makes much sense. Now Processing stores temporary
> results as memory layers
As long as you have enough memory, that's a good approach. When your
system starts paging, you better have a backup plan.
> and uses .shp/.geopackage as intermediate
> format because these formats are compatible with wast majority of 3rd
> party tools.
I dare to guess that those flexible enough to have picked up geopackage
in the last years are likely to pickup flatgeobuf in the near future too.
> Also as flatgeobuf does not provide random write capability it can be
> slow in some cases.
In which cases does processing do random writes? I think in most cases
it streams data from/to feature sources or to feature sinks.
Matthias
More information about the QGIS-Developer mailing list
