[QGIS-Developer] Flatgeobuf for processing
Even Rouault even.rouault at spatialys.com
Sat May 9 03:27:32 PDT 2020
On samedi 9 mai 2020 08:54:06 CEST Matthias Kuhn wrote:
> Hi Richard,
> On 5/8/20 5:24 PM, Richard Duivenvoorde wrote:
> > About Tobias' flatgeobuf: instead of a shp/gpkg file alternative, would
> > this not be a very good candidate to store our intermediate processing
> > steps in (which was shp, not shure what it is now?)?
> Good shout!
> I would love to see someone systematically test it with processing.
A few insights of the GDAL implementation (CC'ing Björn):
- the default behaviour is to generate a flatgeobuf file with the spatial index
- to do so, a temporary file is created with the features serialized as soon as they are passed
to GDAL
- the bounding box of each feature is added in a in-memory vector (40 bytes / feature)
- this vector is sorted with the Packed Hilbert R-Tree sorting order
- the final FlatGeobuf file is written with the features also sorted accordingly (doesn't require
bring them all into memory, so not an issue)
One potential issue could be for huge files (> tens of millions of features), where the size of
the vector storing the bounding box could become significant (10 millions features = 400
MB), especially on 32 bit processes.
So probably not going to be a limitation for common usage (and someone really eager to
limit the RAM usage could probably use a merge sort, with the array split into sub ones,
stored onto several files on disk, and bringing into RAM only chunks for final sorting. That
would be fun to write !!!)
If not writing a spatial index, the writing is done in a streaming way in the final file, without
storing in RAM the bounding box of each feature.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200509/cbc603de/attachment.html>
More information about the QGIS-Developer mailing list
