[QGIS-Developer] icons for temporal controller
Richard Duivenvoorde rdmailings at duif.net
Tue May 12 06:41:58 PDT 2020
I tried Samweli's proposal:
https://github.com/qgis/QGIS/pull/36374
Regards,
Richard
On 5/12/20 3:09 PM, James Bambury wrote:
> An alternative might be <| and |> which sometimes takes a next/previous
> frame role in vid editing/playing software.
> Does some some general UI inconsistency on this, blender for instance
> uses |< & >| as move to start/endpoints but I'm sure I've seen it as
> other uses elsewhere.
> regards,
> James
> On Tue, 12 May 2020 at 08:40, Aurelio Pires <anvpires at gmail.com
> <mailto:anvpires at gmail.com>> wrote:
>     On 2020-05-12 07:55, Richard Duivenvoorde wrote
>     > That is why I think Samweli's proposal to add a pipe-symbol ('|')
>     to the
>     > fastforward to end and start: '<<' and '>>' as a best fitting
>     proposal:
>     > '|<<' and '>>|'.
>     > Regards,
>     > Richard
>     Yes, I agree
>     Regards,
>     APires
>     > On 5/11/20 8:54 PM, Alexandre Neto wrote:
>     >> Hi Richard et al.
>     >> I am also used to see the |< and >| as go to start or go to end (next
>     >> video or chapter), I would take << and >> as rewind and fast forwards
>     >> Alexandre Neto
>     >> A segunda, 11/05/2020, 19:21, Richard Duivenvoorde
>     <rdmailings at duif.net <mailto:rdmailings at duif.net>
>     >> <mailto:rdmailings at duif.net <mailto:rdmailings at duif.net>>> escreveu:
>     >>      On 5/8/20 2:41 PM, Samweli wrote:
>     >>      > Hi Richard,
>     >>      > Yes we definitely need to have commonly used  icons in
>     this scenario.
>     >>      > The way we thought about this is |< and >| icons would mean
>     >>      "rewind one step
>     >>      > then pause and play forward one step then pause,
>     respectively".
>     >>      > I think the improvement should be on the << and >> icons
>     changed
>     >>      to |<< and
>     >>      >>> | meaning "rewind to start then pause and skip to end
>     then pause,
>     >>      > respectively".
>     >>      > Some little explanation
>     >>      https://en.wikipedia.org/wiki/Media_control_symbols
>     >>      Hi Samweli,
>     >>      Sorry for my late reply. So after seeing your wikipedia page
>     it looks
>     >>      correct what we have now... So maybe leave it as is.. I have to
>     >>      reconnect some wires in my head I think :-)
>     >>      I like your refinement though. I think adding the | tot the
>     go to
>     >>      start/end would help (me at least)
>     >>      Thanks & Regards,
>     >>      Richard
>     >>      _______________________________________________
>     >>      QGIS-Developer mailing list
>     >>      QGIS-Developer at lists.osgeo.org
>     <mailto:QGIS-Developer at lists.osgeo.org>
>     <mailto:QGIS-Developer at lists.osgeo.org>>
>     >>      List info:
>     https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     >>      Unsubscribe:
>     > QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
