[QGIS-Developer] Appending Features to a layer
Alexandre Neto senhor.neto at gmail.com
Wed May 13 08:33:32 PDT 2020
The GDAL export o postgreSQL tools in processing allows you to append
features to an existing layer. Disable the overwrite option, and enable the
append option.
https://docs.qgis.org/3.10/en/docs/user_manual/processing_algs/gdal/vectormiscellaneous.html#export-to-postgresql-available-connections
If needed in a script, you can call that algorithm too. No need to reinvent
anything.
Best regards,
Alexandre Neto
A quarta, 13/05/2020, 15:06, Germán Carrillo <carrillo.german at gmail.com>
escreveu:
> Hi Luis,
> if you are fine with a plugin solution, then there is one called "Append
> Features to Layer" [1] that adds a new algorithm to QGIS Processing.
> If you run it once via Processing Toolbox, then in the Processing History
> you'll get the Python command, which you could use in your code to append
> features to layers.
> BTW, QGIS Processing will come with an append features to existing layer
> out-of-the-box. It's planned for QGIS 3.14. See it in action [2].
> Regards,
> Germán
> [1] https://github.com/gacarrillor/AppendFeaturesToLayer/
> [2] https://github.com/qgis/QGIS/pull/35641
> El mié., 13 may. 2020 a las 6:25, Jorge Gustavo Rocha (<jgr at di.uminho.pt>)
> escribió:
>> Hola Luís,
>> The options are quite simple. You can see them in this SO question:
>> https://gis.stackexchange.com/questions/87404/how-to-write-a-new-layer-to-postgresql-from-qgis-plugin/360270#360270
>> You should create a temporary layer with the original one, plus the
>> features you want to append. Then you write it to the database.
>> Does it help?
>> Regards,
>> Jorge Gustavo
>> On 13/05/20 11:57, Luís Miguel Royo Pérez wrote:
>> > Hi all,
>> > I'm seeking a way to append features to a layer when exporting into a
>> > PostGIS layer.
>> > For now I'm using the tool QgsVectorLayerExporter.
>> > I'm doing something like this
>> > QgsVectorLayerExporter(uri, "postgres", fields, layer.wkbType(),
>> > utils().crs, overwrite,{}).addFeatures([feat for feat in
>> > layer.getFeatures()])
>> > Inside the curly brackets I know I can place the options, but I can't
>> > find where are these options documented. Or wether these options can
>> > help me in my task of append features to a QGIS layer.
>> > Can anyone point me in the right direction in this task of appending
>> > features?
>> > Kind regards.
>> > Luís Miguel Royo Pérez.
>> > Analista-Programador GIS
>> > C/ Antic Regne de Valencia nº 4. Manises (Valencia)
>> > Teléfono:+34  679846103
>> > webs:
>> > inisig.com <http://inisig.com>
>> > geofibra.com <https://geofibra.com>
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Gabinete 3.29 (Piso 3)
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
>    |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200513/4e5c962c/attachment-0001.html>
More information about the QGIS-Developer mailing list
