Hi, > It is when you install Recommends, which now enabled by default. > > > here is the list of packages installed when doing sudo apt-get install > > qgis-server: > > The list is shorter when using: > > apt install --no-install-recommends qgis-server thanks, I wasn't aware of this change. regards -- G --
