[QGIS-Developer] QGIS Server now install a full DE?
Uros Preloznik
uros00 at gmail.com
Mon May 18 22:46:56 PDT 2020
I also noticed this as Giovanni wrote. It does not make sense to install
all this on Linux server (no desktop). Can anyone explain why was this
change necessary?
Should we change documentation on setup part?
thanks
Uroš
V V čet., 14. maj 2020 ob 15:31 je oseba Sebastiaan Couwenberg <
sebastic at xs4all.nl> napisala:
> On 5/14/20 3:24 PM, Giovanni Manghi wrote:
> > I noticed that the list of dependencies to be installed was weirdly very
> > long, and in fact after finishing it was also installed Gnome... is this
> > normal now?
> It is when you install Recommends, which now enabled by default.
> > here is the list of packages installed when doing sudo apt-get install
> > qgis-server:
> The list is shorter when using:
> apt install --no-install-recommends qgis-server
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200519/802a9616/attachment.html>
