[QGIS-Developer] QGIS Server now install a full DE?
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon May 18 23:47:21 PDT 2020
On 5/19/20 7:46 AM, Uros Preloznik wrote:
> Can anyone explain why was this change necessary?
The problem seems to be:
qgis-server Depends:
python3-qgis Depends:
python3-qgis-common Depends:
libqgis-customwidgets Depends:
qttools5-dev-tools Depends:
qt5-assistant Depends:
libqt5webkit5 Depends:
libqt5positioning5 Recommends:
geoclue-2.0 Depends:
libnotify4 Recommends:
gnome-shell | notification-daemon
And via gnome-shell you many more gnome packages installed.
The change to install Recommends by default was announced in October 2007:
https://lists.debian.org/debian-devel-announce/2007/08/msg00000.html
This makes sense because the Debian Policy documents Recommends as:
The Recommends field should list packages that would be found together
with this one in all but unusual installations.
https://www.debian.org/doc/debian-policy/ch-relationships.html#binary-dependencies-depends-recommends-suggests-enhances-pre-depends
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
