[QGIS-Developer] Getting changelog ready for 3.14
Tim Sutton tim at kartoza.com
Sun May 24 13:11:24 PDT 2020
Thanks Toto
Toto I trust you, just remove something if you think it is wrong so that we can keep things efficient. Thanks I will take those out.
Regards
Tim
> On 24 May 2020, at 21:00, Totò Fiandaca <pigrecoinfinito at gmail.com> wrote:
> Hi everyone,
> I noticed that these 4 PR belong to previous versions and not to 3.14 Pi
> https://changelog.qgis.org/en/qgis/version/3.14/#show-dimensions-metadata-on-wms-layer-metadata <https://changelog.qgis.org/en/qgis/version/3.14/#show-dimensions-metadata-on-wms-layer-metadata> (#33539 https://github.com/qgis/QGIS/pull/33539 <https://github.com/qgis/QGIS/pull/33539>)
> https://changelog.qgis.org/en/qgis/version/3.14/#featureprocessing-add-line-density-algorithm <https://changelog.qgis.org/en/qgis/version/3.14/#featureprocessing-add-line-density-algorithm> (#33525 https://github.com/qgis/QGIS/pull/33525 <https://github.com/qgis/QGIS/pull/33525>)
> https://changelog.qgis.org/en/qgis/version/3.14/#feature-add-support-for-displaying-wmts-legend-gra <https://changelog.qgis.org/en/qgis/version/3.14/#feature-add-support-for-displaying-wmts-legend-gra> (#33829 https://github.com/qgis/QGIS/pull/33829 <https://github.com/qgis/QGIS/pull/33829>)
> https://changelog.qgis.org/en/qgis/version/3.14/#when-dd-rotation-fails-evaluate-fallback-static-va <https://changelog.qgis.org/en/qgis/version/3.14/#when-dd-rotation-fails-evaluate-fallback-static-va> (#33282 https://github.com/qgis/QGIS/pull/33282 <https://github.com/qgis/QGIS/pull/33282>)
> regards
> Il giorno dom 24 mag 2020 alle ore 11:25 Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> ha scritto:
> Awesome thanks!
>> On 24 May 2020, at 10:24, Frank Sokolic <sokolic at worldonline.co.za <mailto:sokolic at worldonline.co.za>> wrote:
>> Hi Tim,
>> Thanks for setting up the changelog. I'll proofread the entries and will also check the grammar.
>> Regards, Frank.
>> On 2020/05/23 23:39, Tim Sutton wrote:
>>> Hi
>>>> On 23 May 2020, at 13:52, Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>>> On 5/22/20 5:03 PM, Tim Sutton wrote:
>>>>> Hi
>>>>> Toto: I re-ingested the Changelog entries now.
>>>>> Richard: For the entry images that are linked to GitHub embedded images
>>>>> we either need to import them over or just link out to them in the
>>>>> generated RST. If you tell me which you prefer I will ask Anita Hapsari
>>>>> to help make that happen before the release.
>>>> Hi Tim,
>>>> I think I prefer these images IN the export. Then at least the 'old' way
>>>> will just work.
>>>> If that is in place I can have a further look at using for example
>>>> https://github.com/sphinx-contrib/images <https://github.com/sphinx-contrib/images>
>>>> Or if that fails (as it does now with me), then I can have a look at
>>>> generating thumbnails myself and add some ::target to them to the real
>>>> image or so
>>>> I also tested current export, and besides the usual little hick-ups
>>>> (because of content of the items) there are some new bigger ones, of
>>>> which I created issues:
>>>> https://github.com/kartoza/prj.app/issues/1186 <https://github.com/kartoza/prj.app/issues/1186>
>>>> https://github.com/kartoza/prj.app/issues/1187 <https://github.com/kartoza/prj.app/issues/1187>
>>>> https://github.com/kartoza/prj.app/issues/1188 <https://github.com/kartoza/prj.app/issues/1188>
>>>> https://github.com/kartoza/prj.app/issues/1189 <https://github.com/kartoza/prj.app/issues/1189>
>>>> It would be great if Anita could find some time before the release to
>>>> have a look into these.
>>> Ah great, thanks for filing those. @anita can you take a look through those?
>>> @Frank last release you were wanting to help out with the changelog - will be great if you are available to pitch in.
>>> @Richard for now I think I will manually just move the images into the entries which should fix the issues with embedded images.
>>> Regards
>>> Tim
>>>> TIA & regards,
>>> <KartozaNewLogoThumbnail.jpg>
>>> Tim Sutton
>>> Co-founder: Kartoza
>>> Ex Project chair: QGIS.org <http://qgis.org/>
>>> Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
>>> Desktop GIS programming services
>>> Geospatial web development
>>> GIS Training
>>> Consulting Services
>>> Skype: timlinux
>>> IRC: timlinux on #qgis at freenode.net <http://freenode.net/>
>>> I'd love to connect. Here's my calendar link <https://calendly.com/timlinux/30min> to make finding time easy.
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Tim Sutton
> Co-founder: Kartoza
> GIS Training
> Consulting Services
> Skype: timlinux
> Ing. Salvatore Fiandaca
> mobile.:+39 327.493.8955
> m: pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>
> C.F.: FNDSVT71E29Z103G
> P.IVA: 06597870820
> membro QGIS Italia - http://qgis.it/ <http://qgis.it/>
> socio GFOSS.it - http://gfoss.it/ <http://gfoss.it/>
> blog: https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/>
> FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>  <https://www.facebook.com/qgis.it/>
> TW:  <http://goog_95411464/>https://twitter.com/totofiandaca <https://twitter.com/totofiandaca>
> 43°51'0.54"N  10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
Tim Sutton
Co-founder: Kartoza
GIS Training
Consulting Services
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200524/edb1f49a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200524/edb1f49a/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
