[QGIS-Developer] Getting changelog ready for 3.14
Tim Sutton tim at kartoza.com
Sun May 24 13:29:00 PDT 2020
Hi
@Nyall - I remember once you proposed a set of guidelines for the way that changelog entries should be written - can you possibly dig up your list again - I will add it in the changelog site.
@Frank and others reviewing entries - I would like to remove developer technical jargon from the entries if possible - e.g. “This PR” and similar references to PRs and git workflows which will probably be meaningless to most users.
Regards
Tim
> On 24 May 2020, at 21:11, Tim Sutton <tim at kartoza.com> wrote:
> Thanks Toto
> Toto I trust you, just remove something if you think it is wrong so that we can keep things efficient. Thanks I will take those out.
> Regards
> Tim
>> On 24 May 2020, at 21:00, Totò Fiandaca <pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>> wrote:
>> Hi everyone,
>> I noticed that these 4 PR belong to previous versions and not to 3.14 Pi
>> https://changelog.qgis.org/en/qgis/version/3.14/#show-dimensions-metadata-on-wms-layer-metadata <https://changelog.qgis.org/en/qgis/version/3.14/#show-dimensions-metadata-on-wms-layer-metadata> (#33539 https://github.com/qgis/QGIS/pull/33539 <https://github.com/qgis/QGIS/pull/33539>)
>> https://changelog.qgis.org/en/qgis/version/3.14/#featureprocessing-add-line-density-algorithm <https://changelog.qgis.org/en/qgis/version/3.14/#featureprocessing-add-line-density-algorithm> (#33525 https://github.com/qgis/QGIS/pull/33525 <https://github.com/qgis/QGIS/pull/33525>)
>> https://changelog.qgis.org/en/qgis/version/3.14/#feature-add-support-for-displaying-wmts-legend-gra <https://changelog.qgis.org/en/qgis/version/3.14/#feature-add-support-for-displaying-wmts-legend-gra> (#33829 https://github.com/qgis/QGIS/pull/33829 <https://github.com/qgis/QGIS/pull/33829>)
>> https://changelog.qgis.org/en/qgis/version/3.14/#when-dd-rotation-fails-evaluate-fallback-static-va <https://changelog.qgis.org/en/qgis/version/3.14/#when-dd-rotation-fails-evaluate-fallback-static-va> (#33282 https://github.com/qgis/QGIS/pull/33282 <https://github.com/qgis/QGIS/pull/33282>)
>> regards
>> Il giorno dom 24 mag 2020 alle ore 11:25 Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> ha scritto:
>> Awesome thanks!
>>> On 24 May 2020, at 10:24, Frank Sokolic <sokolic at worldonline.co.za <mailto:sokolic at worldonline.co.za>> wrote:
>>> Hi Tim,
>>> Thanks for setting up the changelog. I'll proofread the entries and will also check the grammar.
>>> Regards, Frank.
>>> On 2020/05/23 23:39, Tim Sutton wrote:
>>>> Hi
>>>>> On 23 May 2020, at 13:52, Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>>>> On 5/22/20 5:03 PM, Tim Sutton wrote:
>>>>>> Hi
>>>>>> Toto: I re-ingested the Changelog entries now.
>>>>>> Richard: For the entry images that are linked to GitHub embedded images
>>>>>> we either need to import them over or just link out to them in the
>>>>>> generated RST. If you tell me which you prefer I will ask Anita Hapsari
>>>>>> to help make that happen before the release.
>>>>> Hi Tim,
>>>>> I think I prefer these images IN the export. Then at least the 'old' way
>>>>> will just work.
>>>>> If that is in place I can have a further look at using for example
>>>>> https://github.com/sphinx-contrib/images <https://github.com/sphinx-contrib/images>
>>>>> Or if that fails (as it does now with me), then I can have a look at
>>>>> generating thumbnails myself and add some ::target to them to the real
>>>>> image or so
>>>>> I also tested current export, and besides the usual little hick-ups
>>>>> (because of content of the items) there are some new bigger ones, of
>>>>> which I created issues:
>>>>> https://github.com/kartoza/prj.app/issues/1186 <https://github.com/kartoza/prj.app/issues/1186>
>>>>> https://github.com/kartoza/prj.app/issues/1187 <https://github.com/kartoza/prj.app/issues/1187>
>>>>> https://github.com/kartoza/prj.app/issues/1188 <https://github.com/kartoza/prj.app/issues/1188>
>>>>> https://github.com/kartoza/prj.app/issues/1189 <https://github.com/kartoza/prj.app/issues/1189>
>>>>> It would be great if Anita could find some time before the release to
>>>>> have a look into these.
>>>> Ah great, thanks for filing those. @anita can you take a look through those?
>>>> @Frank last release you were wanting to help out with the changelog - will be great if you are available to pitch in.
>>>> @Richard for now I think I will manually just move the images into the entries which should fix the issues with embedded images.
>>>> Regards
>>>> Tim
>>>>> TIA & regards,
>>>> <KartozaNewLogoThumbnail.jpg>
>>>> Tim Sutton
>>>> Co-founder: Kartoza
>>>> Ex Project chair: QGIS.org <http://qgis.org/>
>>>> Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
>>>> Desktop GIS programming services
>>>> Geospatial web development
>>>> GIS Training
>>>> Consulting Services
>>>> Skype: timlinux
>>>> IRC: timlinux on #qgis at freenode.net <http://freenode.net/>
>>>> I'd love to connect. Here's my calendar link <https://calendly.com/timlinux/30min> to make finding time easy.
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Tim Sutton
>> Co-founder: Kartoza
>> GIS Training
>> Consulting Services
>> Skype: timlinux
>> Ing. Salvatore Fiandaca
>> mobile.:+39 327.493.8955
>> m: pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>
>> C.F.: FNDSVT71E29Z103G
>> P.IVA: 06597870820
>> membro QGIS Italia - http://qgis.it/ <http://qgis.it/>
>> socio GFOSS.it - http://gfoss.it/ <http://gfoss.it/>
>> blog: https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/>
>> FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>  <https://www.facebook.com/qgis.it/>
>> TW:  <http://goog_95411464/>https://twitter.com/totofiandaca <https://twitter.com/totofiandaca>
>> 43°51'0.54"N  10°34'27.62"E - EPSG:4326
>> “Se la conoscenza deve essere aperta a tutti,
>> perchè mai limitarne l’accesso?”
>> R. Stallman
>> Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
> Tim Sutton
> Co-founder: Kartoza
> GIS Training
> Consulting Services
> Skype: timlinux
Tim Sutton
Co-founder: Kartoza
GIS Training
Consulting Services
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200524/870e3a51/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200524/870e3a51/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
