[QGIS-Developer] Getting changelog ready for 3.14
Totò Fiandaca pigrecoinfinito at gmail.com
Mon May 25 01:18:59 PDT 2020
Hi everyone,
according to my script the new features introduced in QGIS 3.14 Pi are 133
against the 125 present in Changelog 3.14.
One way to compare changelogs is to use the PR number, so I kindly ask if
it was possible to have a detailed list of features with a PR number.
I tried to use the description, but in some cases it has been changed.
thanks and good job
https://pigreco.github.io/changelog314/
Il giorno dom 24 mag 2020 alle ore 22:29 Tim Sutton <tim at kartoza.com> ha
scritto:
> Hi
> @Nyall - I remember once you proposed a set of guidelines for the way that
> changelog entries should be written - can you possibly dig up your list
> again - I will add it in the changelog site.
> @Frank and others reviewing entries - I would like to remove developer
> technical jargon from the entries if possible - e.g. “This PR” and similar
> references to PRs and git workflows which will probably be meaningless to
> most users.
> Regards
> Tim
> On 24 May 2020, at 21:11, Tim Sutton <tim at kartoza.com> wrote:
> Thanks Toto
> Toto I trust you, just remove something if you think it is wrong so that
> we can keep things efficient. Thanks I will take those out.
> Regards
> Tim
> On 24 May 2020, at 21:00, Totò Fiandaca <pigrecoinfinito at gmail.com> wrote:
> Hi everyone,
> I noticed that these 4 PR belong to previous versions and not to 3.14 Pi
> https://changelog.qgis.org/en/qgis/version/3.14/#show-dimensions-metadata-on-wms-layer-metadata
>  (#33539 https://github.com/qgis/QGIS/pull/33539)
> https://changelog.qgis.org/en/qgis/version/3.14/#featureprocessing-add-line-density-algorithm
>  (#33525 https://github.com/qgis/QGIS/pull/33525)
> https://changelog.qgis.org/en/qgis/version/3.14/#feature-add-support-for-displaying-wmts-legend-gra
>  (#33829 https://github.com/qgis/QGIS/pull/33829)
> https://changelog.qgis.org/en/qgis/version/3.14/#when-dd-rotation-fails-evaluate-fallback-static-va
>  (#33282 https://github.com/qgis/QGIS/pull/33282)
> regards
> Il giorno dom 24 mag 2020 alle ore 11:25 Tim Sutton <tim at kartoza.com> ha
> scritto:
>> Awesome thanks!
>> On 24 May 2020, at 10:24, Frank Sokolic <sokolic at worldonline.co.za>
>> wrote:
>> Hi Tim,
>> Thanks for setting up the changelog. I'll proofread the entries and will
>> also check the grammar.
>> Regards, Frank.
>> On 2020/05/23 23:39, Tim Sutton wrote:
>> Hi
>> On 23 May 2020, at 13:52, Richard Duivenvoorde <rdmailings at duif.net>
>> wrote:
>> On 5/22/20 5:03 PM, Tim Sutton wrote:
>> Hi
>> Toto: I re-ingested the Changelog entries now.
>> Richard: For the entry images that are linked to GitHub embedded images
>> we either need to import them over or just link out to them in the
>> generated RST. If you tell me which you prefer I will ask Anita Hapsari
>> to help make that happen before the release.
>> Hi Tim,
>> I think I prefer these images IN the export. Then at least the 'old' way
>> will just work.
>> If that is in place I can have a further look at using for example
>> https://github.com/sphinx-contrib/images
>> Or if that fails (as it does now with me), then I can have a look at
>> generating thumbnails myself and add some ::target to them to the real
>> image or so
>> I also tested current export, and besides the usual little hick-ups
>> (because of content of the items) there are some new bigger ones, of
>> which I created issues:
>> https://github.com/kartoza/prj.app/issues/1186
>> https://github.com/kartoza/prj.app/issues/1187
>> https://github.com/kartoza/prj.app/issues/1188
>> https://github.com/kartoza/prj.app/issues/1189
>> It would be great if Anita could find some time before the release to
>> have a look into these.
>> Ah great, thanks for filing those. @anita can you take a look through
>> those?
>> @Frank last release you were wanting to help out with the changelog -
>> will be great if you are available to pitch in.
>> @Richard for now I think I will manually just move the images into the
>> entries which should fix the issues with embedded images.
>> Regards
>> Tim
>> TIA & regards,
>> <KartozaNewLogoThumbnail.jpg>
>> *Tim Sutton*
>> *Co-founder:* Kartoza
>> *Ex Project chair:* QGIS.org <http://qgis.org/>
>> Visit http://kartoza.com to find out about open source:
>> Desktop GIS programming services
>> Geospatial web development
>> GIS Training
>> Consulting Services
>> *Skype*: timlinux
>> *IRC:* timlinux on #qgis at freenode.net
>> I'd love to connect. Here's my calendar link
>> <https://calendly.com/timlinux/30min> to make finding time easy.
>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> *Tim Sutton*
>> GIS Training
>> Consulting Services
>> *Skype*: timlinux
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/
> *blog:*
> * https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
> - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
> <https://www.facebook.com/qgis.it/> *
> *TW:  <http://goog_95411464/>**https://twitter.com/totofiandaca
> <https://twitter.com/totofiandaca>*
> 43°51'0.54"N  10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di
> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
> in relazione alle finalità per le quali è stato ricevuto. E' vietata
> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
> di informare tempestivamente il mittente e distruggere la copia in proprio
> possesso.
> *Tim Sutton*
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *Tim Sutton*
> GIS Training
> Consulting Services
> *Skype*: timlinux
*blog:*
*TW:  <http://goog_95411464>**https://twitter.com/totofiandaca
R. Stallman
di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di
possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200525/c36dcfd5/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200525/c36dcfd5/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
