[QGIS-Developer] Getting changelog ready for 3.14
Frank Sokolic sokolic at worldonline.co.za
Mon May 25 02:43:01 PDT 2020
Hi Tim,
I've had a look through the changelog and have allocated each entry to a
category. Authors might want to check that their entries are allocated
correctly as I might have classified some of them incorrectly. I've also
replaced "PR" with words like "update", "feature" or "change" and have
removed references to github and QEP where I came across them.
Regards,
Frank.
On 2020/05/24 22:29, Tim Sutton wrote:
> Hi
> @Nyall - I remember once you proposed a set of guidelines for the way
> that changelog entries should be written - can you possibly dig up
> your list again - I will add it in the changelog site.
> @Frank and others reviewing entries - I would like to remove developer
> technical jargon from the entries if possible - e.g. “This PR” and
> similar references to PRs and git workflows which will probably be
> meaningless to most users.
> Regards
> Tim
More information about the QGIS-Developer mailing list
