[QGIS-Developer] Linux users: wanna flatpak?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu May 28 05:27:17 PDT 2020
Really great!
Worked liked a charm.
Beginning to like Flatpak :)
So, more or less, sorry for the noise. The solution was right there, it
would have only taken to read it ;)
Cheers,
Bernd
On 28.05.20 14:22, Richard Duivenvoorde wrote:
> On 5/28/20 2:18 PM, Bernd Vogelgesang wrote:
>> Wow,
>> thanx a lot!
>> Umh, just reading https://github.com/flathub/org.qgis.qgis
>> Seems I can just reinstall the flatpak with the needed module
>> |flatpak run --command=pip3 org.qgis.qgis install scipy --user Will give
>> it a try! Cheers, Bernd |
> Ah, YES, that is it. Apparently without the --user it flatpak will try
> to install it in the non-user space of it's environment.
> So THAT works:
> flatpak run --command=pip3 org.qgis.qgis install urllib3 --user
> Then I was able to download "Distant measurement styles" successfully!
> Thanks! Will add it to the docs
> Regards,
More information about the QGIS-Developer mailing list
