[QGIS-Developer] WFS-T, postgis and triggers
Denis Rouzaud
denis.rouzaud at gmail.com
Sun Nov 1 22:29:25 PST 2020
But couldn't we just add an option to the layer to re-fetch the data once
inserted?
Le dim. 1 nov. 2020 à 10:39, Carlo A. Bertelli (Charta s.r.l.) <
carlo.bertelli at gmail.com> a écrit :
> I suppose we could benefit from the help of another Alessandro, the father
> of Spatialite. I think he is already working on WFS3. Maybe this could lead
> to an enhancement of libspatialite to make XML/JSON sources a more
> interactive part of Spatialite itself or a virtualwms data provider for
> Spatialite (like virtualpg).
> c
> On Sun, Nov 1, 2020 at 9:58 AM Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
>> Hi,
>> +1 with Denis, this is a quite common scenario, but the caching issue,
>> combined with the good old WFS-T implementation spatialite provider issues
>> looked like a big challenge.
>> I think the future transactional version of WFS3 - OGC APIF should speed
>> up and simplify a lot the protocol part. On my side, I was just waiting fo
>> it to happen to raise the topic again.
>> Concerning the client side caching, I'm not up to date with the potential
>> spatialite provider enhancement.
>> Having a reliable and efficient way to edit WFS-T would be really nice.
>> But as Alessandro points out, our application with a lot of database
>> intelligence will trigger a lot of data refresh in any case and we will
>> have then some lags.
>> Best
>> Régis
>> Le jeu. 29 oct. 2020 à 15:11, Denis Rouzaud <denis.rouzaud at gmail.com> a
>> écrit :
>>> Le jeu. 29 oct. 2020 à 15:07, Alessandro Pasotti <apasotti at gmail.com> a
>>> écrit :
>>>> On Thu, Oct 29, 2020 at 2:59 PM Denis Rouzaud <denis.rouzaud at gmail.com>
>>>> wrote:
>>>> > Hi all,
>>>> > I have a WFS-T layer with a Postgis DB behind it.
>>>> > On my table, I have an insert trigger (before insert) which sets a
>>>> field.
>>>> > When I create a feature on this layer in QGIS, I don't get back the
>>>> value of this field (I have to refresh the data, by re-opening QGIS for
>>>> instance).
>>>> > Is this expected?
>>>> Yes. The features are locally cached in a SQLite layer and a newly
>>>> created feature will be stored locally and not retrieve from the
>>>> server.
>>>> > Is there anything we can fix?
>>>> Of course yes but it would require re-fetching the feature(s) after an
>>>> insert or an update, I think it will slow things down.
>>> This could be done asynchronously?
>>> It sounds like a quite common scenario (or not if nobody complained...).
>>> Thanks for the answer anyway.
>>>> Besides that there is no perfect solution to server-side changes: if
>>>> some other user will trigger a data change on the DB we will of course
>>>> miss it anyway.
>>>> > Am I doing something wrong?
>>>> No.
>>>> Cheers
>>>> Alessandro Pasotti
>>>> QCooperative: www.qcooperative.net
>>>> ItOpen: www.itopen.it
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201102/1e879471/attachment.html>
