[QGIS-Developer] WFS-T, postgis and triggers
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Nov 2 00:15:46 PST 2020
Good idea -
But make it an option for the specific layers, so it's possible to turn
it "off" or "on" depending of the situation. And "off" should be the
default.
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 02-11-2020 kl. 07:29 skrev Denis Rouzaud:
> But couldn't we just add an option to the layer to re-fetch the data
> once inserted?
> Le dim. 1 nov. 2020 à 10:39, Carlo A. Bertelli (Charta s.r.l.)
> <carlo.bertelli at gmail.com <mailto:carlo.bertelli at gmail.com>> a écrit :
> I suppose we could benefit from the help of another Alessandro,
> the father of Spatialite. I think he is already working on WFS3.
> Maybe this could lead to an enhancement of libspatialite to make
> XML/JSON sources a more interactive part of Spatialite itself or a
> virtualwms data provider for Spatialite (like virtualpg).
> c
> On Sun, Nov 1, 2020 at 9:58 AM Régis Haubourg
> <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> wrote:
> Hi,
> +1 with Denis, this is a quite common scenario, but the
> caching issue, combined with the good old WFS-T implementation
> spatialite provider issues looked like a big challenge.
> I think the future transactional version of WFS3 - OGC APIF
> should speed up and simplify a lot the protocol part. On my
> side, I was just waiting fo it to happen to raise the topic again.
> Concerning the client side caching, I'm not up to date with
> the potential spatialite provider enhancement.
> Having a reliable and efficient way to edit WFS-T would be
> really nice. But as Alessandro points out, our application
> with a lot of database intelligence will trigger a lot of data
> refresh in any case and we will have then some lags.
> Best
> Régis
> Le jeu. 29 oct. 2020 à 15:11, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> a
> écrit :
> Le jeu. 29 oct. 2020 à 15:07, Alessandro Pasotti
> <apasotti at gmail.com <mailto:apasotti at gmail.com>> a écrit :
> On Thu, Oct 29, 2020 at 2:59 PM Denis Rouzaud
> <mailto:denis.rouzaud at gmail.com>> wrote:
> > Hi all,
> > I have a WFS-T layer with a Postgis DB behind it.
> > On my table, I have an insert trigger (before
> insert) which sets a field.
> > When I create a feature on this layer in QGIS, I
> don't get back the value of this field (I have to
> refresh the data, by re-opening QGIS for instance).
> > Is this expected?
> Yes. The features are locally cached in a SQLite layer
> and a newly
> created feature will be stored locally and not
> retrieve from the
> server.
> > Is there anything we can fix?
> Of course yes but it would require re-fetching the
> feature(s) after an
> insert or an update, I think it will slow things down.
> This could be done asynchronously?
> It sounds like a quite common scenario (or not if nobody
> complained...).
> Thanks for the answer anyway.
> Besides that there is no perfect solution to
> server-side changes: if
> some other user will trigger a data change on the DB
> we will of course
> miss it anyway.
> > Am I doing something wrong?
> No.
> Cheers
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> <http://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201102/cc2b8954/attachment-0001.html>
