[QGIS-Developer] mac os builds failing with some PDAL error
Jürgen E. Fischer
jef at norbit.de
Wed Nov 11 06:52:38 PST 2020
On Wed, 11. Nov 2020 at 13:56:22 +0100, Denis Rouzaud wrote:
> /Users/runner/work/QGIS/QGIS/src/core/processing/qgsprocessingfeedback.cpp:110:72:
> error: no member named 'GetFullVersionString' in namespace 'pdal'; did you
> mean 'pdal::Config::fullVersionString'?
> https://github.com/qgis/QGIS/runs/1384622146#step:6:2588
> Probably PDAL_VERSION_MAJOR_INT is not correctly set.
> https://github.com/qgis/QGIS/blob/master/src/core/processing/qgsprocessingfeedback.cpp#L107
> Is anyone looking into this?
hm, it's detecting PDAL version 0.6.0. Which is older than what bionic has.
Is that correct? It happens to be the same version as qgis-depsâ¦
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) RheinstraÃe 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201111/cf9afe35/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201111/cf9afe35/attachment.ksh>
