[QGIS-Developer] mac os builds failing with some PDAL error
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Wed Nov 11 12:40:38 PST 2020
PDAL on MacOS is 2.2.0 (see
https://qgis.org/downloads/macos/nightly/qgis_nightly_master_20201110_122948.deps).
0.6.0 is version of the qgis-deps packages.
ok, found the problem will try to fix tomorrow:
https://github.com/qgis/QGIS-Mac-Packager/issues/97
Peter
On Wed, Nov 11, 2020 at 3:52 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi,
> On Wed, 11. Nov 2020 at 13:56:22 +0100, Denis Rouzaud wrote:
> /Users/runner/work/QGIS/QGIS/src/core/processing/qgsprocessingfeedback.cpp:110:72:
> > error: no member named 'GetFullVersionString' in namespace 'pdal'; did
> you
> > mean 'pdal::Config::fullVersionString'?
> > https://github.com/qgis/QGIS/runs/1384622146#step:6:2588
> > Probably PDAL_VERSION_MAJOR_INT is not correctly set.
> https://github.com/qgis/QGIS/blob/master/src/core/processing/qgsprocessingfeedback.cpp#L107
> > Is anyone looking into this?
> hm, it's detecting PDAL version 0.6.0. Which is older than what bionic
> has.
> Is that correct? It happens to be the same version as qgis-depsâ¦
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) RheinstraÃe 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201111/8bff947d/attachment.html>
