[QGIS-Developer] mac os builds failing with some PDAL error
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Thu Nov 12 00:25:24 PST 2020
this should be fixed in next nightly build, uploaded fixed qgis-deps-0.6.0-2
On Wed, Nov 11, 2020 at 9:40 PM Peter Petrik <
peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> PDAL on MacOS is 2.2.0 (see
> https://qgis.org/downloads/macos/nightly/qgis_nightly_master_20201110_122948.deps).
> 0.6.0 is version of the qgis-deps packages.
> ok, found the problem will try to fix tomorrow:
> https://github.com/qgis/QGIS-Mac-Packager/issues/97
> Peter
> On Wed, Nov 11, 2020 at 3:52 PM Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi,
>> On Wed, 11. Nov 2020 at 13:56:22 +0100, Denis Rouzaud wrote:
>> /Users/runner/work/QGIS/QGIS/src/core/processing/qgsprocessingfeedback.cpp:110:72:
>> > error: no member named 'GetFullVersionString' in namespace 'pdal'; did
>> you
>> > mean 'pdal::Config::fullVersionString'?
>> > https://github.com/qgis/QGIS/runs/1384622146#step:6:2588
>> > Probably PDAL_VERSION_MAJOR_INT is not correctly set.
>> https://github.com/qgis/QGIS/blob/master/src/core/processing/qgsprocessingfeedback.cpp#L107
>> > Is anyone looking into this?
>> hm, it's detecting PDAL version 0.6.0. Which is older than what bionic
>> has.
>> Is that correct? It happens to be the same version as qgis-depsâ¦
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH) RheinstraÃe 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> https://www.norbit.de
>> QGIS release manager (PSC) Germany IRC: jef on
>> FreeNode
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201112/c275c88d/attachment.html>
