[QGIS-Developer] [Qgis-user] Tip: test a Pull Request for Windows users
Andreas Neumann
a.neumann at carto.net
Thu Oct 1 07:10:59 PDT 2020
Really nice - I didn't know about this either. Quite convenient!
Andreas
On 2020-10-01 16:00, Richard Duivenvoorde wrote:
> Hi Devs/Users,
> Not sure if I was the only ignorant one here :-)
> But see: https://github.com/qgis/QGIS/issues/39081
> After Even Rouault had fixed an issue, I build and tested the PR on my Linux machine.
> BUT... the person from the issues then told me that it was possible to 'just download the artifact from the azure windows test suite and use that to test the PR'.
> So for others (Windows) users: IF your issue is fixed and you want to test the fix yourself in an easy way by logging in in Github, and then get the artifact from the Windows azure test (at the PR), unzip/unpack it to disk and just run that version!!
> No need to compile yourself, or wait for the nightly build to finish/be available.
> I hope this is an eye-opener for others too (credits to @pathmapper !!)
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201001/b1825a1a/attachment.html>
