[QGIS-Developer] Offline Editing plugin
Tim Sutton
tim at kartoza.com
Wed Oct 7 01:47:43 PDT 2020
Hi Matteo
Yes I have experienced similar issues - often getting corrupted projects
when I try to round trip data. IMHO we should remove that plugin and point
people to QFieldSync or Mergin as better options for syncing to a device.
Regards
Tim
On Tue, Oct 6, 2020 at 11:39 AM matteo <matteo.ghetta at gmail.com> wrote:
> Hi all,
> I had the chance to use a little bit the Offline Editing with a
> "complex" project and data coming from a postgis DB.
> * when syncing back the layers are not in the same groups as the
> original project
> * a lot of problems with the widgets (e.g. you loose a relation
> reference layer - key map)
> * enum data type are not maintained (knowing this data type is not part
> of gpkg nor spatialite I was hoping for an automatic conversion to value
> map or similar)
> IMHO (but of course this is a personal opinion), QFieldSync makes the
> same things, but better, even if you don't load the project into QField.
> Other people experienced the same situation?
> Cheers and thanks
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201007/2b394a66/attachment-0001.html>
