[QGIS-Developer] Travis failing in QGIS-Documentation
DelazJ
delazj at gmail.com
Wed Oct 7 09:22:08 PDT 2020
Hi devs,
QGIS-Documentation master build is failing due to "ModuleNotFoundError: No
module named 'qgis'" (see
https://travis-ci.org/github/qgis/QGIS-Documentation/builds/733643360#L2217)
So I wonder if there's any issue with the docker build.
BTW, going to the code repo readme, the docker build badge is
indicated as manual (I have no idea what that means) but the
associated URL points to a 404. Could be nice this is fixed. Thanks
Regards,
Harrissou
Le lun. 7 sept. 2020 à 16:05, DelazJ <delazj at gmail.com> a écrit :
> Hi devs,
> A gentle ping to help us fix doc travis reports (actually PyQGIS Cookbook
> tests infrastructure in). Unless there's some ongoing efforts I'm not aware
> of.
> Thanks.
> Harrissou
> Le mar. 1 sept. 2020 à 13:11, DelazJ <delazj at gmail.com> a écrit :
>> Hi,
>> Like Matteo, I can't locally test the doctest build so travis/docker are
>> the masters and last resort here.
>> I gave a look to the travis reports and the code testing parts of the
>> docs are the reasons for failure. But I'm not sure the recent broken master
>> docker is the only reason. I tried to fix some obvious issues in our code
>> samples pointed by the various and changing reports of travis but there are
>> a bunch of feedback I do not understand (or don't know where to look for a
>> fix) so would be grateful if someone can give it a look. A single small PR
>> ending with the red cross from Travis is making me crazy. I have summarized
>> some of the issues at
>> https://github.com/qgis/QGIS-Documentation/labels/build%2Fdoctest%2Ftravis
>> Thanks in advance,
>> Harrissou
>> Le ven. 28 août 2020 à 10:51, matteo <matteo.ghetta at gmail.com> a écrit :
>>> Hi Richard,
>>> > in is in the conf.py:
>>> > https://github.com/qgis/QGIS-Documentation/blob/master/conf.py#L343
>>> oh right.... my fault.. but tests are still failing with a compiled
>>> version of QGIS. Can I ask you how you user.mk file looks like?
>>> Cheers and thanks
>>> Matteo
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201007/15c4c9ff/attachment.html>
