[QGIS-Developer] How to get a generated CRS from an Unknown CRS
Nyall Dawson nyall.dawson at gmail.com
Wed Oct 7 18:03:17 PDT 2020
On Wed, 7 Oct 2020 at 19:13, René-Luc Dhont <rldhont at gmail.com> wrote:
> Thanks Nyall for your answer.
> Is it really just a string issue ?
> If the text is "Custom CRS",  will the CRS stored in the project (or in
> the datasource) never become "invalid projection" ?
It shouldn't -- you should be able to confirm this by checking the WKT
definition of the projection and ensuring that it hasn't changed.
Nyall
> René-Luc
> Le 07/10/2020 à 09:20, Nyall Dawson a écrit :
> > This has been fixed recently for 3.16.
> > It's basically just a string issue -- instead of reading "Unknown CRS"
> > the text should be "Custom CRS". The CRS will still transform
> > correctly (as you've deduced).
> > Nyall
More information about the QGIS-Developer mailing list
