[QGIS-Developer] [Qgis-developer] Select Within plugin, for Centroid Within and Point on Surface Within selections
Stefan Keller
sfkeller at gmail.com
Wed Oct 7 17:07:26 PDT 2020
Salut Harrissou,
Many thanks for the hint! My bad.
It's actually "Extract by location" what I'm looking for.
I somehow don't get the logic:
1. of the Vector menu tool names (Analysis, Research, Geoprocessing,
Geometry and Data management); and
2. the criteria, when a Geoprocessing algorithm is being shown in the menu
(like "Select by location"), and when not (Extract by location).
:Stefan
Am Mi., 7. Okt. 2020 um 22:05 Uhr schrieb DelazJ <delazj at gmail.com>:
> Hi,
> Stefan, something like the "Select by location" algorithm [0]? I could
> find mention of it in 2.6 docs [1] so not something new.
> [0]
> https://docs.qgis.org/3.10/en/docs/user_manual/processing_algs/qgis/vectorselection.html#select-by-location
> [1]
> https://docs.qgis.org/2.6/en/docs/user_manual/processing_algs/qgis/vector_selection_tools/selectbylocation.html
> Regards,
> Harrissou
> Le mer. 7 oct. 2020 à 20:32, Stefan Keller <sfkeller at gmail.com> a écrit :
>> Dear Heikki, dear QGIS devs
>> Recently I had the need to select features based on polygon(s) from
>> another layer.
>> IMHO this is a functionality which comes pretty close to "Geoprocessing
>> Intersection". In ArcGIS this exists quite some time.
>> After desperately seeking around I stumbled upon this nice plugin "Select
>> Within" which mainly does the job and which exists since QGIS 1.8 or so.
>> => Q1: Did I miss somethin in QGIS v3.10?
>> => Q2: If no, are there any plans to integrate this functionality into
>> core?
>> :Stefan
>> Am Mi., 26. Aug. 2015 um 00:50 Uhr schrieb Heikki Vesanto <
>> heikki.vesanto at gmail.com>:
>>> Hi all,
>>> Replicating the SQLite based methodology in:
>>> http://gisforthought.com/centroid-within-selection-in-qgis/
>>> But using a plugin. Was surprisingly straightforward, but an
>>> absolutely essential tool if selection postcode areas that fall within
>>> local council areas for example.
>>> Performance needs some work, and would love to see the functionality
>>> added to the Spatial Query core plugin in the future.
>>> Also having some issues with my metadata.txt file.
>>> It reads:
>>> [general]
>>> name=Select Within
>>> description=Centroid within and point of surface within selection
>>> between vector layers.
>>> category=Vector
>>> version=0.1
>>> experimental=False
>>> qgisMinimumVersion=2.0
>>> author=Heikki Vesanto
>>> email=heikki.vesanto at thinkwhere.com
>>> homepage=gisforthought.com
>>> deprecated=False
>>> repository=https://github.com/HeikkiVesanto/QGIS_Centroid_Within/
>>> tracker=https://github.com/HeikkiVesanto/QGIS_Centroid_Within/issues
>>> <https://github.com/HeikkiVesanto/QGIS_Centroid_Within/tracker=https://github.com/HeikkiVesanto/QGIS_Centroid_Within/issues>
>>> tags=vector, select, selection, polygon, analysis
>>> But on the http://plugins.qgis.org/plugins/SelectWithin/ page the
>>> repository points to:
>>> http://plugins.qgis.org/plugins/SelectWithin/repo%20url
>>> Tried re-uploading and re-saving my metadata but alas no help.
>>> Any questions happy to answer.
>>> -Heikki
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201008/95390ef1/attachment.html>
