[QGIS-Developer] Offline Editing plugin
Nyall Dawson
nyall.dawson at gmail.com
Wed Oct 7 18:02:22 PDT 2020
On Tue, 6 Oct 2020 at 20:40, matteo <matteo.ghetta at gmail.com> wrote:
> Hi all,
> I had the chance to use a little bit the Offline Editing with a
> "complex" project and data coming from a postgis DB.
> * when syncing back the layers are not in the same groups as the
> original project
> * a lot of problems with the widgets (e.g. you loose a relation
> reference layer - key map)
> * enum data type are not maintained (knowing this data type is not part
> of gpkg nor spatialite I was hoping for an automatic conversion to value
> map or similar)
> IMHO (but of course this is a personal opinion), QFieldSync makes the
> same things, but better, even if you don't load the project into QField.
Matthias knows this situation better than me and will be able to
confirm, but QFieldSync calls the SAME code as the offline editing
plugin...!
Nyall
> Other people experienced the same situation?
> Cheers and thanks
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
