Hi Nyall, > Matthias knows this situation better than me and will be able to > confirm, but QFieldSync calls the SAME code as the offline editing > plugin...! waiting for Matthias answer then :) But: if QFieldSync is already using the code of OfflineEditing then we can let the API usage and remove the plugin GUI? Cheers and thanks Matteo
