[QGIS-Developer] Extend the API to fix a bug for a patch release
David Signer david at opengis.ch
Tue Oct 13 21:40:53 PDT 2020
Thanks, Nyall.
> (But it makes me think -- instead of the (offline) suffix used by
default, a nicer behaviour would be to instead leave the name
unchanged and show a new indicator icon representing "offline"
status!)
Such an icon would be nice anyway regardless if there is a suffix or not.
The default suffix should be (offline) to provide full backwards
compatibility. Of course modern plugins will not use any suffix then.
Cheers
Dave
On Tue, Oct 13, 2020 at 12:53 AM Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On Tue, 13 Oct 2020 at 05:29, David Signer <david at opengis.ch> wrote:
> > Hi there
> > Last week there was a discussion regarding the issues with the offline
> editing plugin already.
> > One of the main problems with the projects created by the offline
> editing functions are the layernames. They get the static suffix "
> (offline)". This leads to issues with expressions or widgets like e.g. the
> value relation.
> > We thought about solving it by adding a parameter called suffix to the
> function. This suffix should be " (offline)" by default.
> > But it gives Plugins like e.g. QFieldSync the possibility to pass an
> empty suffix, what will keep the layername unchanged and would fix the
> issues in the expressions and widgets. It would be completely backwards
> compatible and would not have any influence on other parts of the code.
> > Would this Bugfix have a chance to be in the patch release 3.16.1?
> This is perfectly acceptable -- feel free to open a PR for 3.16.0.
> We've always allowed API revisions, refactoring, and code
> optimisations during freeze.
> status!)
> Nyall
> > Thanks for your feedback and cheers
> > Dave
> > David Signer - signedav
> > david at opengis.ch
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201014/68c2c0f0/attachment.html>
More information about the QGIS-Developer mailing list
