[QGIS-Developer] running Travis locally?
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Oct 21 10:20:38 PDT 2020
Hi Vincent,
The tests are running on Docker.
You basically just need to do what is done on Travis:
https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/before_script.sh
https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/script.sh
If you strip down these 2 files, you should end up with 3-4 docker commands
to build the image, build QGIS and run the tests.
Another approach is to run Travis interactive debugging:
https://www.mail-archive.com/qgis-developer@lists.osgeo.org/msg44142.html
(not sure how up to date it is, and I found this approach to be a bit
cumbersome personally)
Best wishes,
Denis
Le mer. 21 oct. 2020 à 19:10, Vincent Cloarec <vcloarec at gmail.com> a écrit :
> Hi all,
> I've got an issue only on a Travis test, but on my side with ubuntu,
> everything is ok, and the test does not fail. Not very convenient to
> debug...
> Is there a way to run Travis locally, that will permit to speed up
> debugging and avoid to pollute the offical Travis CI.
> Regards.
> Vincent
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201021/7df919c0/attachment.html>
