[QGIS-Developer] running Travis locally?
Vincent Cloarec vcloarec at gmail.com
Wed Oct 21 10:40:33 PDT 2020
Thanks Denis,
I will try this.
Vincent
Le mer. 21 oct. 2020 à 13:20, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi Vincent,
> The tests are running on Docker.
> You basically just need to do what is done on Travis:
> https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/before_script.sh
> https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/script.sh
> If you strip down these 2 files, you should end up with 3-4 docker
> commands to build the image, build QGIS and run the tests.
> Another approach is to run Travis interactive debugging:
> https://www.mail-archive.com/qgis-developer@lists.osgeo.org/msg44142.html
> (not sure how up to date it is, and I found this approach to be a bit
> cumbersome personally)
> Best wishes,
> Denis
> Le mer. 21 oct. 2020 à 19:10, Vincent Cloarec <vcloarec at gmail.com> a
> écrit :
>> Hi all,
>> I've got an issue only on a Travis test, but on my side with ubuntu,
>> everything is ok, and the test does not fail. Not very convenient to
>> debug...
>> Is there a way to run Travis locally, that will permit to speed up
>> debugging and avoid to pollute the offical Travis CI.
>> Regards.
>> Vincent
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201021/9caff316/attachment-0001.html>
More information about the QGIS-Developer mailing list
