[QGIS-Developer] Question
Raymond Nijssen r.nijssen at terglobo.nl
Wed Oct 21 23:48:27 PDT 2020
Hi Guillaume,
A 5% progress after 5 days still sounds extremely slow! That would take
approximately 100 days to finish on 1 core, or 2 days (72 hours!) on 32
cores.
I don't know how large or complicated these shapefiles are, but you
might try to find the solution in another way.
- Make sure you are using indexes?
- Select non-overlapping shapes and delete them?
- Split the files in parts?
- Move to Postgis? (Am I allowed to suggest that here? ;) )
@Marco Shouldn't that code end up in QGIS or is it still in your repo
for a reason?
Kind regards,
Raymond
On 22-10-2020 07:20, Marco Hugentobler wrote:
> Hi Guillaume
>  >My question: Is there a way to take advantage of the fact that I have
> 32 cores on my computer with QGIS to make this calculation? I don't
> understand why it is so slow.
> Yes, there is. Compile the code from the
> 'processing_multithreaded_vector' branch in my repo
> (https://github.com/mhugent/QGIS/tree/processing_multithreaded_vector).
> It calculates the difference operation on multiple cores (see also
> https://github.com/qgis/QGIS/pull/33365).
> Regards,
> Marco
> Am 22.10.20 um 03:05 schrieb guillaume martel:
>> Hi,
>> I don't know if I'm writing at the wrong place...
>> I have 2 shapefiles and I want to do a "difference operation"
>> (https://docs.qgis.org/3.10/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html).
>> My issue is as follow: Even though I have a powerful computer, after 5
>> days the calculation is only at 5%.
>> Thank you for your help.
>> Guillaume
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
